Question about Sony Ericsson GC89 EDGE / Wireless LAN PC Card (48904)
DRIVER Sony Ericsson GC89 EDGE / Wireless LAN PC Card
2 Suggested Answers
SOURCE: How can i get drivers for sony vaio laptop
You can download all the original drivers from here:
http://www.sony-asia.com/support/download/291551/product/vgn-ns15g
Good luck
Posted on May 04, 2009
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
Wireless lan won't work on sony vaio vcg-rb43 after disk restore
Go to Windows Updates and see if there is an update their sometimes that happens with drivers. Start there Updates and install all the updates hardware updates as well. If that does not assist you there may be a fix at the Sony Vaio support drivers and download for your driver start there. I would download the driver online for the wireless software. Click Here to go to the driver site enter your model and info they request and download whatever you need from there. This should get you up and running again. I hope that this assisted you. Note download the Network anything that has to do with wireless Lan John
Apr 19, 2012 | Sony VAIO VGC-RB34G PC Desktop
Can I use 2 GC89s on one system?
If you can fit it in there should be no problem
Feb 28, 2011 | Sony Ericsson GC89 (610214611642) Wireless...
I want to get all my sony vaio vgn-s590b driver program because i cant get wifi signal n lan for the internet'
Unfortunately, the Wireless card in the VAIO model VGN-S580B does not support n standard. The integrated Intel PRO/Wireless 2200BG Network Connection Driver supports IEEE 802.11b and IEEE 802.11g standards. It is require to use an external Wireless card to use the n standard.
However, here is the link to download all the drivers for your computer model:
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=VGNS580B&LOC=3
Thanks
Jan 03, 2011 | Sony VAIO VGN-S580B (VGNS580B03) PC...
VAIO VGN-NS190J/S 15.4-Inch Notebook PC (2.0GHz Intel Core 2 Duo Processor T5800, 4GB RAM, 250G: The wifi light won't turn on when I put the switch...
They issue is due to the corrupted SmartWi Connection Utility Software in the Computer.
You will need to re-install the Wireless LAN Driver, Updates, and the SmartWi Connection Utilities in the Computer to fix the issue with the Wireless.
You can download the Wireless LAN Driver, Updates and the SmartWi Connection Utility from Sony Support Site.
Below are the links.
Wireless LAN Driver
Wireless LAN Driver Update 1
Wireless LAN Driver Update 2
  1. Please download and save each file on the Desktop.
  2. After that double click on the Original Wireless LAN Driver to begin the installation.
  3. Please follow the onscreen instructions to complete the installation.
  4. After that, restart the Computer for the settings to take the effect.
  5. After restarting the Computer, please install the Updates.
  6. Make sure that you restart the Computer after each installation.
  7. Then, please re-install the "SmartWi Connection Utility in the Computer.
You can download the SmartWi Connection Utility from here.
  1. Download and install the SmartWi Connection Utility in the Computer.
  2. after the installation, please turn ON the Wireless Adapter using the SmartWi Connection Utility.
  3. Please click "Start", "All Programs" and SmartWi Connection Utility to open the Program and turn ON the Wireless Adapter.
  4. After that, please re-configure the Wireless Network connection in the Computer.
  5. This should fix the issue with the Wireless Network connection.
May 18, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
How
go to control panel, performance and maintence, select hardware, and then select device manager, select your wireless card, then select details at top of box, that will give you the device id, cut copy and paste it in google for drivers. should find a site with that specific driver>
Jun 02, 2009 | Sony VAIO® VGN-N350E/W PC Notebook
VGN-S150 wireless LAN switch
You don't need a new computer, a wireless card maybe. The problem is either a wireless driver glitch or the wireless card has failed. Start by uninstalling the wireless drivers from the device manager, then reboot. The machine will find the wireless card and reinstall the drivers. If this doesn't work, then take the card out (located under a panel on the bottom of the machine), clean the card, the slot, and the connectors on the two leads/wires. Sometimes a little dirt or corrosion build up will cause this. At this point, if the problem persists, then the card has malfunctioned and needs to be replaced.
Jul 22, 2008 | Sony VAIO VGN-S150 Notebook
Sony Ericsson GC89 EDGE / Wireless LAN PC Card (48904) Logo
41 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
