Question about LG Flatron 995FT 19" CRT Monitor
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed. Whenever I try to change,it will try by displaying black screen for a while but couldn't be changed. I have downloaded a latest graphics controller from www.intel.com, but also not working. Is it monitor driver problem ? pliz help ! With regards Gandhi
  • Anonymous Oct 16, 2008
    cannot change monitor resolution, it is indicated that default monitor is it's default
  • jhootz Nov 15, 2008
    i have the drivers for my monitor, as for the driver for that vgasave thing, well it can't be found by the PC. it has a yellow question mark next to it in the device manager and when i tried to install/update the driver, it said none can be found!
    PLEASE HELP!
I AM HAVING KOBIAN P1845GLM mother board and i want video controller for that board where i can get it
Posted on Jan 06, 2009
  • 749 Answers
Check your video card specifications
install some drivers for it
Posted on Oct 30, 2008
    Problem Solver:
  • 11 Answers
Some 15" monitors do not support 1024 by 768, check your monitor specifications if it does. google on the net with the exact monitor model no. and see if it supports.
Posted on Sep 28, 2007
SOURCE:
Appears on screen"input not supported"
Start windows in safe mode - press F8 on the keyboard during the boot process and wait for the startup options menu to appear. Select Safe mode and see if this works. If so, then once in safe mode, change the display settings to a lower resolution. the maximum resolution for this monitor is 1024x768. Set it to 800x600 to see if it works at the lower resolution first.
Mar 01, 2011 | AOC A15X221 15 in. LCD Television
Blurred screen
There is the possiblility that this program may have corrupted the video driver or a similar issue.
You may be able to go to system restore and back the computer up a day before you installed that program...all your settings will go back to that point but any data you have added will still be there.
Aug 31, 2009 | BenQ FP71E 17" LCD Monitor
NVidia GeForce FX 5700LE graphic card-resolution issue
check if your monitor supports resoulution above 800x600 or something is wrong with your OS.
Jul 03, 2009 | XFX GeForce FX5700LE, (256 MB) Graphic...
Resolution Problem
go to your desktop display properties then go to setting then go to advance then monitor tab chack your screen refesh rate may be 85Hertz.now change rate to 56Hertz and apply.now you change your resolution 800*600 to 1024*768.
Dec 20, 2008 | LG L1915S 19" LCD Monitor
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Aug 05, 2008 | Computers & Internet
Settings for dcl lcd monitor
Your laptop resolution is greater than the external monitor can handle. From your laptop, try changing the screen resolution to 800x600, if it works, up the ante to 1024x768. You can bring it up again until you find a comfortable screen resolution. You will eventually stop to a point when your external monitor displays about 80% of the laptop screen. That is, back to your original problem. But you get the idea. Cheers!
Mar 27, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Satellite Pro 1905-S301
if u get normal beep of ram then check your disply resolution .
when u start your pc press F8 key continus then if u get menu choos best configuration loading in menu.then change your resolution to 800x600 or 1024x768 .if u not get menu and your cpu ;s smps still work but not disply on monitor then clear your bioss . get away the cmos cell for 15 minutes from its case.then start your pc .i think your problem is solved.
Mar 21, 2008 | Toshiba Satellite 1905-S301 Notebook
Monitor problems
Mar 20, 2008 | Computers & Internet
Refresh rates and resolutions
What's the question? There's no real need to go above 85Hz, I think in nvindia you have to go to an advance menu and you can force an output, google it.
Dec 12, 2007 | iiyama Vision Master Pro 510 22" CRT...
Open Questions:
See all LG Flatron 995FT 19" CRT Monitor Questions
LG Flatron 995FT 19" CRT Monitor Logo
264 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
