Question about Radio Communications
Realistic scanner Pro 2024
All I get on my scanner is Static even after I Put in the Codes. I've Tried to use a different Antenna and I still get Static. I Can't figure out what's going on It was working about 6 or 8 months ago then it was Packed in a Box to be Moved to a New Home.
sir fixalot
  • 146 Answers
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Posted on Jan 04, 2008
Gavin93
  • 66 Answers
SOURCE: scanner static
Use the channel lock out control, unless it is a frequency that you listen to, you may have interference that is causing random static. use a noise filter mechanism to minimize this problem, or buy a specialized scanner antenna that's guaranteed to minimize static.
If no avail, you may need to send it in to a store.
Hope this helps!
Posted on Jul 04, 2008
Gavin93
  • 66 Answers
SOURCE: Radio scanner not receiving
The Realistic Pro-2025 relies on a quartz lock-loop signal synthesizer to receive signals, the synthesizer might of gone bad, chalk it up to old age. The Realistic PRO (Progressive Receiving Occilator) models are not around anymore, they went obsolete years ago. It's nice that you have one, they are worth some money on eBay. However I'm afraid it will cost you more money to fix the synthesizer than the radio is actually worth. It would be best to use your Radio Shack PRO-49. Realistic is a division of Radio Shack founded by Tandy Corp, basically you've been using a Radio Shack scanner the whole time. So if you have any complaints, take it up with them, you won't find Realistic anymore.
Hope this helps!
Posted on Jul 08, 2008
BillB-SA
  • 2761 Answers
SOURCE: need codes for a Realistic Model#20-129 Pro-2024 Scanning Receive
Here;s a link where you can download and print the manual for your scanner:
http://support.radioshack.com/support_electronics/doc31/31323.htm
Bill B.
San Antonio
Posted on May 16, 2009
SOURCE: Cobra 150GTL DX
try doing the freq mod that anymhz mentioned its probably the easiest radio to open up there is i will walk you thru it if needed
Posted on Aug 06, 2009
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
Sep 06, 2015 | Radio Communications
Replacement Telescopic Antenna
See if this fits the bill. Otherwise stop in at a radio shack store. They sometimes have these n stock.
BuyTraxxas
Mar 01, 2014 | Radio Communications
Whenever i turn on my pro-82 scanner all i get is static and have tried squelch and reset
Check your antenna connections, if the connections are good then try a different antenna. Most likely that is the problem if it's the scanner. If your trying to scan Public Safety Frequencies you may be running into a situation where they have gone Digital and your scanner is Analog or they may have encrypted their frequency or control channels so the scanners won't work.
Sep 21, 2011 | Radio Shack Pro-82 Scanner
Hi, i have a PRO 2025 Realistic Scanner, it is a
eBay has numerous antennas that will work for you, mostly in the $20 -$30 range. Here's a link to one of the listings:
http://cgi.ebay.com/NEW-MINI-MOBILE-SCANNER-ANTENNA-MAGNET-MAG-MOUNT-KIT-/220596857646?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335c98eb2e
You can also pick up a compatible antenna at any Radio Shack store.
Bill B
May 11, 2010 | Radio Communications
Well you will need to get it at Radio Shack,they just plug right in the back of it . nice ...hope this helps..
Mar 18, 2010 | Radio Communications
Need codes for a Realistic Model#20-129 Pro-2024 Scanning Receive
Bill B.
San Antonio
Mar 29, 2009 | Audio Players & Recorders
Radio Shack Pro Scanner
I know that if you turn your scanner off over a few days you can loose your frequency # or it will lock the channels out. if they or l/o just unlock then. I also know that all police and ect. went digital, you would to have a scanner that is digital. When they changed to digital some for the frequency # have changed. I had to get the new ones and put them in.
k.ditterline@yahoo.com
Jun 08, 2008 | Radio Shack Pro-97 Handheld Scanner
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Feb 28, 2008 | Uniden BC248CLT Base Scanner
Realistic
snickers1 hi, if I googled in the right scanner, yours is an older one with an antenna that screws into a stud inside the top cover. Here is a link to a site that has a lot of the older stuff covered. He's been selling CB stuff for over 30 years. You'll have to look at your scanner inside to see if it's male or female thread. I hope this helps with what your looking for,, Mechanic
http://www.kenselectronics.com/lists/amfm.htm
Dec 30, 2007 | Radio Communications
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
