My split ac`s compressor got overheated and stops working after 15 min but fan was running
    Sergeant:
  • 317 Answers
Check refrigerant level and pressures - could be over charged.
Posted on Oct 22, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
This is because the compressor is thermoing out meaning it is getting to hot and the windings on the compressor are opening causing the compressor to go off, it is a safety for the compressor so it does not get ruined. have an ac company or someone who knows what they are doing come take a loo at it, it sound like bad start components to the compressor, also have then check the freon levels as well.
  • 230 Answers
SOURCE: poetable AC compressor licks in for 10 min
It is probably either the high pressure switch or the frost control. The high temp switch usually trips because the condenser coil is dirty which does not allow it to exhaust heat very well. The frost control will trip if the system gets below 39 degrees on the pipes. This is usually do to low refrigerant or dirty filters. Good Luck!
Posted on Jul 03, 2008
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
SOURCE: Compressor will not come on. Fan runs great.
I fixed it. I had a dirty connection on the starter relay for the compressor. Thanks again for the help.
Posted on May 18, 2009
  • 587 Answers
SOURCE: We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 587 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
I HAVE 1.5 TON SPLIT A/C WHAT SIZE OF RUNNING CAPACITOR WILL WORK IN COMPRESSOR?
the capacitor that is required is the same size as what is fitted
it will read as voltage and uf number
best have a ac technician check it out as it may not be the capacitor but the power board
some ac units have a capacitor that is in effect two capacitors in one to run the compressor and the cooling fan as well
best get the technician in as it could save a lot of money in the long run
Aug 08, 2015 | Dayton Permanent Split Capacitor Motor Fan
Any body tell me what is the problem with my 1.5 Dawlance split ac It gives perfect cooling in night and morning but in afternoon its compressor turn on and off every after 15 minutes. And due to this my...
when the heat ambient temps go up . the start capacitor gets hot to turn on fan and heat sensor for the compressor senses it and turns off . check the run/start cap first
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
Samsung 2.0TR split ac compressor getting heated up and tripped after running for 10 mins
High limit switch set to high, obstruction in the system, or your compressor may be wearing out.
Apr 12, 2013 | Heating & Cooling
My 9000 Btu Kenwood Continental Series split unit shuts down compressor after every 10-15 minuits regardles of room temp. Gas pressure is OK & I have tried replacenig cooling sensor but to no use. I am...
Sounds like the compressor may be overheating. You need to check the outdoor condenser coil it may be stopped up with dirt, in turn, overheating the compressor. The condenser coil looks like a radiator and the outdoor fan blows through it, in a sense releasing the hot air from the building. If the coil is stopped up, it can not release the heat. You can wash this coil out with a hose and sprayer. Just be careful not to get the motor wet and be sure to shut off power.
Jun 24, 2011 | Kenwood Heating & Cooling
My card when speeded at around 50km plus gets heated and AC stops working.. the coolant indicator runs towards the red mark and car needs top be stopped for 10-15 mins.. what could be the problem? have the...
the most likely problem is your themostat is stuck in the closed position, not allowing the radiator to do it's job of cooling you engine. Also, check to make sure your radiator fan turns on once your car is warmed up, if it's not on that also will cause your car to overheat.The worst possible problem could be a blown head gasket, in which case you have to take the car to a shop. Now, for the AC issue, you car is designed to turn off the AC system when it detects that the engine is overheating, this is to help prevent engine damage. Once you have the overheating problem solved your AC will work fine.
Sep 13, 2010 | 2000 Plymouth Voyager
Compressor starts then stops after maybe 3 mins
Any error codes? If not there may be a mechanical fault with the compressor/inverter. The unit is possibly short on refrigerant, so the compressor is not getting enough suction cooling from return gas, so may be clicking off on its internal over temp klixon.
all the best
Jul 05, 2010 | Mitsubishi MS-A09WA Split System Air...
Problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
