Problem with Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum
bissell lift off pet revolution vacuum smells bad when I vacuum!
When I am vacuuming, there is a bad smell that comes out of the vacuum, like stinky dog smell. I empty the canister at least 3 times when i vacuum, I have taken out the filters and washed them, let them dry and try it again, but the smell is still there. I've only had the vacuum a few months. Why is this happening? I love how much dog hair it picks up, but don't like the smell.
Posted by avatar on Apr 26, 2009
Solutions (1)
put a BOUNCE sheet inside the filter
    • By avatarRod Clark Jul 24, 2009
    • put a BOUNCE sheet inside the filter
Suggested Solution (3)
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
  • by Author image Lauren Junge Over a year ago
Source: Bissell Lift Off pet revolution vacuum losing suction
Was this solution helpful?
No
Yes
check your belt
  • by Author image denny adams Over a year ago
Source: BISSELL - Lift-Off Revolution Pet
No
Yes
Check both filters. If one or other is increasingly dirty, wash or clean it out. Also check the air waves leading to the bagless bin canister part. If one air way is blocked the remaining dirt will try and access the bin other way due to the natural vacuum suction aspect.
  • by Author image Ryan S Over a year ago
Source: hair gets stuck in upper
No
Yes
  • The vacuum when turned on has a burnt smell. My husband has taken the vacuum apart, still can't seem to get to the belt. The belt in the...
  • I empty and wipe out the canister each time I use my vacuum. Everytime I go to use it again the vacumm emits a rotten smell from it. It is...
  • The manual says don't use water however I have done this to reduce the smell of dog (picking up dog hair). Wondering if using water may...
  • OUR DYSON DC 17 ANIMAL HAS A SMELL OF ABOUT 50 DOGS THAT HAVEN'T HAD BATHS FOR A YEAR.. WE HAVE TWO DOGS IN THE HOUSE AND THEY ARE KEPT...
Add Your Solution
See all Bissell 37604 Lift-Off Pet Bagless Upright / Problems
