How to open bose AM25 module - Audio Players & Recorders
    New Friend:
  • 3 Answers
First thing -it is exceedingly difficult to get inside the wooden bass box to reach the woofer without seriously damaging the cabinet and virtually rendering the unit worthless. So if someone (like a toddler) has dropped a toy inside the box through the port and you're trying to get it out, better to buy one of those telescopic cameras ($200?) to look inside and attempt to fish it out.
However, if for some reason you are trying to get inside the power amplifier / EQ assembly on the back, this is possible to do without damaging the unit at all. I haven't done this in a while, so I am going from memory (please excuse any mistakes). First, with the bass module sitting upright on the floor and with the port facing away from you, examine the seam where the plastic cover to the amplifier/EQ meets the wooden cabinet. If you look carefully in that seam, you will see something that looks like the teeth of a gear. With a tiny screwdriver (or toothpick?), rotate that to the left (towards the side of the bass box that has the bass and treble controls) until a little triangle of plastic is sticking out and pointing straight up. Now, turn the bass box upside down and look at the place where all the cube speakers are plugged into. You should see two little black screws. Remove these and set aside. Now, stand the bass box on the floor, with the port facing down to the floor. With some effort, you should be able to simply slide the plastic cover off by pushing it from the "top", toward the "bottom". In other words, if the bass box were sitting in its normal position on your floor, you'd want to push the cover down, into the floor. I hope I'm describing it adequately...once you get it, you'll be pleasantly surprised how easy it actually is...and you can tell me if those two little black screws needed to be removed at all.
Posted on Dec 29, 2013
How to hook up bose b1 module into yamaha emx 5000
The Bose B1 bass module is designed to handle up to 125 watts into 8 ohms 40-200 Hz.
The Yamaha EMX 5000 is full 500 watts, and full range. This is not a particularly good match.
EMX5000 Powered Mixers Mixers Live Sound Products Yamaha United States B1 Bass Module Bose L1 Encyclopedia FAQ Wiki
Apr 29, 2014 | Bose Audio Players & Recorders
Need to know how can I open the 123 Bose system when the cheap CD is stuck inside it says it's open but it's not thank you
    • Turn off the device.
    • Disconnect the Acoustimass module power cord from the electrical source. Wait 60 seconds. Plug the cord back into to its power supply.
    • Hold down the "Eject" button.
Feb 01, 2013 | Televison & Video
Replacement part for Bose Cinemate Interface
Replacement parts for Bose Cinemate Interface can be foudn at amazon, take a look here: Amazon com Bose Cinemate parts. I hope this helped. Cheers
Oct 29, 2011 | Bose Cinemate Digital Home Theater System...
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
May 17, 2011 | Bose Acoustimass 15 System
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
Bose 321 tray will not open
If it's flashing on and off, then the DVD drive is the least of your problems. Check to see if there is a dual-voltage switch on the bass module. (if so, set it to 120v if you're in the US) As for the DVD drive--> Try another reset by unplugging the power for at least 30 seconds. Plug it back in, "Bose 321" will appear and disappear from the display, and then press the eject button before you power it back on. Wait about 3-8 seconds. If the drive won't open, it will probably need a repair. $150 for repair w/ new warranty through Bose- 800-367-4998.
Jun 21, 2009 | Bose (321GS) System
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
The bose av321 disk door wont open
Follow these steps:
1. Turn off the unit.
2. Unplug the Acoustimass module power cord from the outlet for 60 seconds, then reconnect it. This
allows the unit to reset itself.
3. Before powering on, press and hold Eject on the media center
Mar 28, 2009 | Bose 3 2 1 GSX System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
54 people viewed this question
 Grubhead
Grubhead
