Question about Mitsubishi HC3000U Multimedia Projector
My Mitsubishi HC3000 keeps blowing bulbs, they won't last a week now? Any suggestions?
    Champion:
  • Mitsubishi Expert
  • 225 Answers
That would be what ever they are using for a bridge rectifier most likely or cheap replacement lamps or overheating do to environment or ...
Posted on Dec 19, 2013
Why do oven lights keep blowing?
make sure the bulbs your using are rated for "appliance duty" if a plain normal house bulb is used the glass is too thin and heat ruins bulb in short time , also make sure heat resistant bulb cover "if there" is in place and not part ways off to one side or the other
May 18, 2015 | Kitchen Ranges
6039 keeps blowing projection bulb
Not sure how long you have had this unit. If it is still under warranty your first call should be to the dealer who sold the unit. It may be part of a bad batch. The dealer should take responsibility for replacing the unit or contacting the manufacturer/distributor. Don't let them tell you it's not their problem. They sold you the item your contract is with them. They bought it from the distributor so they deal with them and the distributor deals with the manufacturer so they deal with them.
Are you maintaining the unit correctly? The filters need to be cleaned regularly, especially in a home environment where a lot of dust can clog the vents causing the unit to overheat.
Plenty of airflow is needed to keep the bulb cool so this is vital.
Cheap bulbs will not last as long as original parts but they should still have a 'rated hours value' under normal use.
Apr 16, 2014 | Mitsubishi WD-60C9 60" DLP HDTV
My dome light bulb keeps blowing. Any suggestions?
check for loose connections . The bulb has to be in tight
Mar 20, 2014 | 1998 Toyota Camry
Denon avr-1312 receiver and mitsubishi hc3000 projector - Video keeps dropping out
Hi, it could be a number of things, go to your browser type in the model followed by support, look at there info, is there enough life in the bulb? if it were mine i would clean the shutter and go on from there but try that what i have said example >>.denon avr-1312 support << hope this helps :)
Nov 30, 2013 | Mitsubishi HC3000U Multimedia Projector
Bulbs keep blowing
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Mar 25, 2013 | Mitsubishi WD-65731 65" HDTV
Fuse for horn keeps blowing on outlander 2007
Someone will need to troubleshoot the circuit to find the short to ground.
Could be in the wiring or the steering wheel.
Oct 02, 2012 | 2007 Mitsubishi Outlander LS
Headlight keeps blowing out 1996 yamaha virago 1100
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight globes keep blowing
Yamaha Virago XV535 1100 1981 1994 Service Manual
OEM parts for Yamaha
Yamaha Virago XV1100K Owner Manual
Jul 22, 2012 | Yamaha Motorcycles
Keeps blowing bulbs. Last one lasted 17 days
check the ballast leads which enter the rear of the lamp compartmnent they can tend to get pushed in slightly and prevent a good connection to the lamp. If the connections all look good then the lamp driver (ballast) is most likely defective
Mar 11, 2012 | Mitsubishi WD-65733 65" HDTV
02 Focus Wagon - Rear tail light/brake light keeps blowing bulbs. Bulb is white when removed, replacement bulb last about a week, then blows again. Any idea what the problem may be.
If a bulb blows white the gas mix in the globe is incorrect and you probably got hold of a bad batch of globes from your supplier. Try buying your bulbs from another source and see if that works out better.
Mar 21, 2011 | 2002 Ford SVT Focus
Mitsubishi HC3000U Multimedia Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
