Question about BEGO Fornax T Centrifugal- induction casting machine BEGO
I need circuit diagram of fornax t because my board has been burned
Faulty Countax PCB with burned out resistor and no Circuit Diagram
You are right to be cautious as it is unlikely the resistor committed hara kiri. The circuit of the board would be fairly simple to puzzle out and draw but I feel the board represents only a small part of the whole circuit of the machine and the reason for the burned resistor could be far from the board.
Circuit boards can be refurbished or more likely an exchange is offered with a refurbished board, but in this case with such a simple board it is likely they will provide only new ones.
The value of the resistor could be calculated by any competent electronics engineer - if he has the will to do so.
I feel you need the circuit diagram of the whole machine or the services of a good white appliance engineer. I suggest you visit the manufacturer's website support section to enquire further.
Jun 16, 2015 | Dryers
Hi I want to save our Daewoo DWF 450 full automatic washing machine. It was broken. I opened,removed and checked the control board then a I found out one of the parts or maybe 3 parts were burned. The...
hello, this is a guess but it sound like resistors or diodes you would need a circuit diagram to tell you the value of the resistor and diodes it would be better to buy a new control board hope it helps
regards
shaun
Mar 13, 2011 | Washing Machines
Power on but no click sound. found some transistors and resistors burn in a small board located at down side of the amp, need scematic circuit diagram to repair it. Please send.
If you have burnt the transistors that are located on the circuit board, then you wont be able to repair it I dont think because in the circuit board there are probibly mulitple layers of electrical wires the are extremely small and fine that would make it impossible to connect the transistor to the right layer. Try contacting the manufacturer though
Oct 08, 2009 | Audio Players & Recorders
Circuit board on AC unit at home was replaced, turned on unit and new circuit board burned also burned spots at the same locations as older board? What could be the problems?
You have something in that circuit that's pulling high amps or shorted. You need to determine what is in that circuit fan, compressor, contactor, wiring, etc and fix it first.
Until you fix that you will keep burning up boards.
Oct 07, 2009 | Heating & Cooling
I have a burned out resister which I need to replace.
R11 = 3.9 K ohm 1/4 w If Q6 burned,change by NTE5657 ( 600v)
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Burn out circuit board
hi! there! replace the burn out circiut board,what ever you pull out the same thing you put back just be sure that has the same model and specification,calibrate and test overload protection,defective overload protection replaced to prevent any burn out,short circuited mostly came to burn those thing that's why imposing preventive maintenace schedule for this kind of large ac central unit is very much significant.mostly timer delay circuit malfunction on large scale unit supplying by three phase a/c source on central control panel board.when ever replacement occured try to put mark or list color coding of specific terminals to connect and isolate short circuit make possible to detect at once before installing the new one and make make record on this for future reference we have several cases like that after buying a new one and replaced still burn again,the common cases is that they did not find the cause of short circuit connection they just relay on circuit board burn out,so it better to make assured that every thing is fine before installing the new one.specially on supply source of circuit.,relay on diagram and manuals take and check all data source as reference this will be a great help.take all necessary precaution this should be done by qualified technical ac support,have a nice day and regards
Mar 31, 2009 | Heating & Cooling
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
Need circuit diagram for bush TV power board Profila-telra 04ta0691 The power supply 04TA0691. Burned out, smoke coming out, dead Hope you can help me out with a new board or diagrams. Best regards...
Diagrams i am sure as you know are not always easy to come by, at least for free. I see that there are available boards online and a company that will rebuild this model of power board for you in UK. ohmsupplies.co.uk is where it is at. looks like $80
Oct 15, 2008 | Televison & Video
Samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Sep 12, 2007 | Samsung HCL4715W 47" Rear Projection...
BEGO Fornax T Centrifugal- induction casting machine BEGO Logo
124 people viewed this question
Top BEGO Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a BEGO Medical Expert? Answer questions, earn points and help others
