Whirlpool f06 error code - Washing Machines
    Scholar:
  • 56 Answers
This error is related to the drive motor. An error with the Motor or associated connectors/harness can generate this error. In most cases replacing the motor will fix the problem.
Temporary fix can be re-seating connectors and limited success has been achevied with harness replacement. Some people have been able to get it to work by disconnecting from mains overnight... but this may only last one or two washes before having to be done again.
Posted on Oct 22, 2013
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
  • 1525 Answers
SOURCE: error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Posted on Mar 22, 2009
  • 4 Answers
SOURCE: F06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
Posted on Mar 24, 2009
  • 4 Answers
SOURCE: f06 error code on Whirlpool duet washer
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet is showing error codes f06 and e02 and wont unlock door or run cycle, what can I do?
Janice,
Here is a link to a website that gives the F06 code, but I cannot find the other code.
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.
Scroll down towards the bottom to find the Duet fault codes.
Jul 28, 2015 | Whirlpool WFW94HEX Duet 5.0 cu. ft. Front...
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Whirlpool duet front load washer, F06 error
FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Open Questions:
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
