Question about Canon Rebel XT / EOS 350D Digital Camera
EOS400D Utility Error
I used the app. CD (Utility, ZoomBrowser and Dig. Ph.Pro) succusfully on Windows XP, no problem downloading. Utility opened as a black window, giving download choices. I've just installed on a new pc, running Vista, and all works except Utility. Plugging the camera in brings an AutoPlay window... when I choose "Download using Canon Utility" it gives me a "Camera not recognized" message. It does seem to work if I choose the "Download using Windows".... but that is not how its suppose to go... am I wrong? Any help will be great! Thanks.
  • 3 Answers
Re: EOS400D Utility Error
I too had the "Camera Not Recognized" problem, until I finally figured out what was causing it.
Yes, I uninstalled and reinstalled the software. I downloaded the most up to date EOS Utility. Blah-blah.
All to no avail.
Then, it struck me.
I have a PC motherboard with several USB ports: 4 on the rear panel and a 2 on the motherboard connected to the front panel of the PC. A couple of years ago, I blew a motherboard by connecting to one of these ports.
I had a 7-port USB hub for all my stuff (printer, cell phone, GPS, label printer, weather station, 2 monitors with built-in hubs) so I began plugging my camera into one of the USB ports on the monitor, meaning camera to hub to hub to PC to avoid the possibility of zapping the motherboard again somehow.
Today I realized that's about when the "Camera Not Recognized" problem started so I plugged the camera directly into the PC and the EOS Utility worked fine.
To make a long story short, try plugging the camera directly into the PC without any intervening hubs.
Good luck.
Posted on Dec 10, 2009
What you need to do is to go and download the latest driver updates from the Canon Website. I had exactly the same problem, and I now downloaded the latest updates for the Utility, and its working 100%.
Posted on Dec 24, 2008
  • 22 Answers
check on the canon website for updated software to install the utility
often new versions are released and are freely available to download off their site
look for your camera model and check the links to download
some new cameras sold today still dont have the applications shipped with the unit
the website is the best place for the latest versions
otherwise use a third party application to transfer the images
picasa by google does a good job too
Posted on Nov 21, 2007
0 characters
3 Points
I have bought a canon EOS 300d camera with out cd. bt when i plug my camera to my computer nothing happens .i tried to do download dpp bt all i fine is dpp updater e.t.c . i have windows xp in installed ....
The updater does not need to have a previous version installed, it will install the stand alone program. However DPP is not the program you need to connect to your camera, what you need is EOS Utility. That is also availible on the Canon website.
May 08, 2011 | Canon Digital Rebel / EOS-300D Digital...
I've lost the installation CD ROM for my Canon 400D SLR. I now have a new laptop and want to download pictures from my camera to my laptop. My camera has a small problem whereby I can't release my SD from...
What you can actually do is download the Zoombrowser which you can use to transfer the pictures in your camera on to a computer. The link to where to download the software is below. Once you're in the website, just choose your computer's operating system (XP, Vista Windows 7, Mac, etc.) then download the zoombrowser. There are other softwares for your camera on the said site which you might want to download as well.
Hope this helps.
Apr 16, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Canon zoombrowser Ex downloading problem
The sd1000 manual says that you will get this error when you have too many pictures on your memory card (aprox 1000). I am not sure how many I had on my 2GB card but it was a lot. I deleted about 50 - 100 pictures and then it started working again and the new pictures downloaded to the computer.
Jun 28, 2008 | Canon PowerShot SD1000 Digital Camera
Try updating the Zoombrowser software.
If you have a connection to the camera, go into my computer and get images directly off the camera using scanner and camera wizard, microsoft's default program. This will at least allow you to transfer your images until you can resolve the software problem.
If you have no connection to the camera via your computer, you need to try some other troubleshooting steps to get a connection. I will post those below in the next post.
May 30, 2008 | Canon PowerShot G7 Digital Camera
Canon PowerShoot A80, error no camra found
Unless you REALLY must use Zoombrowser for some reason, why not simply 'read' the SD/CF Card direct on your PC ?
(you can buy a USB multi-media card/reader writer for less than £10 ...)
Mar 21, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cannot Download pictures from camera to computer
There are numerous solutions for importing digital pictures from your camera to your hard drive. You can use Windows Explorer. By doing this, u maintain complete control over where ur digital images are stored on the computer. If you prefer to use an external application, Google's Picasa remains the best solution available. In addition to being a convenient way to manage your images, Picasa also includes common photo editing functions, supports some of the best photo organization works with low level photo data from your camera, and assists in uploading images to the Web or creating slideshows on your local system. Picasa uses the timeline features that shows when images were taken in relation to all your other images (which only works if your digital camera is set to the correct date). Picasa is free for Windows 2000, Windows XP, and Linux.
Oct 14, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD600 - Problems downloading images - same as below
did you download the canon download app or are you using the installed pc generic camera download app? it will make a diference if the computer cannot reconsile which too use. let me know and we can go from there
Jul 04, 2007 | Canon PowerShot SD600 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
408 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
