Question about Motorola MC9190-GST
Cannot connect with the current connection settings. To change your connection settings tap settings.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
I sometimes will wipe the device clean and install a new version of OS.. but you can call motorola directly and ask for a download link for the build number you want. 1.847.576.5000
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Mobile+Computers/Handheld+Computers/MC9190_G_US-EN
this link should get you in the right spot.. but you want the Cleaner Device Software if you can find it..
load it to a micro/SD card, put it into the device. plug into power, hold 1 & 9 press power.. release all.. press power again and hold yellow laser trigger until it asks you to update loader.. this will reset your device.
we had to disable power save on ours cause the scanner sleeps and shuts off wifi, and took 1-2 minutes to reconnect to our wifi radios.. and the app would time out.. so I suggest doing the same.
Posted on Dec 03, 2013
Help yahoo com
Symptoms You can try these basic steps to troubleshoot Mail on your iPhone, iPad, or iPod touch. If you see a specific error message, follow the basic steps, then the steps for that error message. For example, you might see one of these messages:
  • Cannot get mail
  • Unable to move message
  • Username or password is incorrect
  • Relaying denied
  • Email address rejected by the server
Resolution First, try these basic troubleshooting steps:
  1. Tap Safari and load a webpage. If you can load a webpage, then your device has Internet access. If you can't load a webpage, check your Wi-Fi connection or try a different Internet connection:
    • Try a different Wi-Fi connection.
    • If your iOS device has an active cellular data plan, tap Settings > Wi-Fi and turn off Wi-Fi.
    • If the affected email account is provided by your Internet provider, see if your issue is resolved while connected to your home Wi-Fi network.*
  2. Log in to your email provider's website to make sure that the account is active and the password is correct.
  3. Make sure your settings are correct using Mail Settings Lookup.
  4. Restart your iOS device.
  5. Delete the affected email account from your device.
    1. Tap Settings > Mail, Contacts, Calendars.
    2. Tap the affected email account.
    3. Tap Delete Account.
    4. Add your account again.
* If you can only use your email account while connected to your home network, this might be a limitation put in place by your email service provider. For help, please contact your email service provider.
Follow the steps below for specific alerts.
"Cannot get mail" Make sure you entered the correct password. If you enabled two-step verification through your email service provider, contact them to see if you need a special password for your iOS device.
"Unable to move message"
  1. Tap Settings > Mail, Contacts, Calendar, then tap your email.
  2. Tap Account.
  3. Tap Advanced.
  4. Tap Deleted Mailbox and make sure it's set to Trash.
  5. Tap Advanced > Account, then tap Done.
    Note: If you see the issue again, repeat steps 1 through 3, tap IMAP Path Prefix, then Inbox. After you make your changes, tap Account, then Done.
"Username or password is incorrect" with POP3 account Before you check your email on your iOS device, close it on your computer and other devices.
To see if your account is a POP3 account use the Mail Settings Lookup tool or:
  1. Go to Settings > Mail, Contacts, Calendars and tap the account.
  2. Look for the label POP ACCOUNT INFORMATION.
If your email provider offers IMAP, remove the POP3 account, then add the account with your provider's IMAP settings. POP3 communicates with one mail client at a time. If more than one mail client tries to connect, you might see a username or password error.
"Relaying denied" or "Email address rejected by the server" when you try to send email This error indicates that either an email address is incorrect or your settings aren't correct for your current connection. Make sure the email address is correct for messages in the Outbox or try a different port:
  • If you're on a Wi-Fi network connected to the same network as your email domain, such as your Cable or DSL provider, try port 25:
    2. Tap your email account, then tap Account.
    3. Scroll down and tap Outgoing Mail Server.
    4. Tap Primary Server, then tap Server Port.
    5. Delete the current port and enter 25.
    6. Tap Done.
  • When you connect to a cellular data or a different Wi-Fi network, you need to use an alternate port and authentication, if your email provider supports it. The most common alternate ports are 465 and 587. Check with your email provider for specific settings.
If you still can't send email, you can set up an alternate SMTP server.
Get help troubleshooting iCloud Mail.
Aug 29, 2014 | Yahoo Mail
Sensor to connet to WIFI and Bluetooth is locked, which part of the Iphone 4s should be change ?
Begin troubleshooting with these steps first:
  1. Check that you are in range of the Bluetooth accessory with which you are trying to pair your iPhone, iPad, or iPod touch. Most Bluetooth accessories have a range of approximately 30 feet.
  2. On your iOS device, tap Settings > Bluetooth and find your device in the list. If your device says Not Connected, tap the name of your accessory to attempt to connect it.
  3. Tap Settings > Bluetooth and turn Bluetooth off and then on again.
  4. Make sure that your Bluetooth accessory is turned on and fully charged or connected to power.
  5. Make sure that your Bluetooth accessory is in pairing mode.1
  6. Restart your iOS device.
  7. Tap Settings > Bluetooth and locate the Bluetooth accessory you are currently connected to or attempting to connect to. Then tap [img width="23" height="22" alt="" src="http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/TS4562/TS4562--i-01.png" data-hires="true"> and . Try to pair your Bluetooth accessory again.
    • Note: You may need to re-enter your Bluetooth accessory PIN if your accessory requires one. Some common PINs are 0000, 1111, and 1234.
  8. Restart your Bluetooth accessory by turning it off and then on again1.
  9. Update your device to the latest version of software. See how to update your iPhone, iPad, or iPod touch.
  10. If your Bluetooth accessory has upgradable firmware, check to see that you have the latest version
Thanks,
Apple Support
May 26, 2014 | Apple MC922LL iPhone 4S 16GB AT&T...
HOW TO USE BROWSER.KEEPS ASKING FOR SYSTEM UcPDATE
To get the latest available features as well as the most current enhancements to the Nintendo 3DS system's performance, we recommend downloading the most current System Update.
Important! Your Nintendo 3DS must be connected to the Internet to perform these steps. (How to)
What to do:
  1. Turn on your Nintendo 3DS and access the System Settings by tapping the wrench icon.
  2. Tap "Other Settings."
  3. Tap the right arrow three times to reach page "4."
  4. Tap "System Update."
  5. Tap "OK."
  6. Tap "I Accept."
  7. Tap "OK" to begin the update.
Downloading the system update will resolve the issue you are having.
May 31, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
How do get the internet?
It seems the 3DS does not have internet browsing capabilities as of yet and it is planned to be implemeneted in
late may.
See the following information for more assistance.
http://www.nintendo.com/consumer/systems/3ds/en_na/ht_internet.jsp
The Internet Browser is Currently Not Available
  • The Nintendo 3DS Internet browser is currently not available.
  • It will become available through an update planned for late May.
  • We'll have more information for you after this update becomes available
Regards,
G33k
If this helps please thumbs up my solution!
May 04, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
My dell aximx51v wont connet to the internet when a select a wireless network, add password, it says its connected, when i type www.google.com for instance i get this message; cannot connect cannot connect...
Go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab', and make sure that 'My network card connects to' is set to 'The Internet'.
Hope it works for you!
Cheers! Carlos
Apr 14, 2010 | Dell Axim X51v Pocket PC
Why i see error number 81003005 in yahoo messenger?
This message appear probably because of your computer proxy software by default change your connection properties.
Solution is
Open you internet explorer
  • click tools>>>Internet option>>>connection tap
  • Under Dial-up and Virtual Private Network setting
  • Double click your current internet connection that you are using now
  • Make sure that under Proxy Server, the ‘Use a proxy server for this connection’ isUNCHECKED
  • Now back to connection tab
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again.
Jul 25, 2009 | Yahoo Messenger
AIRTEL GPRS settings for HTC Touch P3452
THIS SHOULD HELP U......
On Windows Mobile 6.x, the steps to configure are as follows:
1. Activate Airtel Live by sending the following SMS to 121: MASALA ACTIVE.
2. The service takes atleast 3-4 hours to get active. Restart the phone and resume configuring.
3. Tap Start -> Settings.
4. Select Connections Tab and tap Connections.
5. Select Advanced Tab, tap Select Networks button to bring up Network Management.
6. Under "Programs that automatically connect to the Internet should connect using:" drop down, tap the New button.
7. In the General Tab, type the name of the settings as Airtel Live
8. Select Modem tab, tap New...
9. Type the name of connection as Airtel Live, select the modem as Cellular Line (GPRS) and tap Next.
10. Type Access Point Name as airtelfun.com and tap next.
11. Leave username, password and domain blank and tap finish.
12. Select Proxy Settings tab. Tap "This network connects to the Internet". This should enable the next check box option.
13. Tap "This network uses a proxy server to connect to the Internet".
14. Type the proxy server as: 100.1.200.99 and then tap Advanced...
15. Tap HTTP, leave the server as 100.1.200.99 and change the port to 8080
16. Similarly tap WAP, Secure WAP and Socks, type the server as 100.1.200.99 but leave the port to defaults. These are optional settings.
17. Tap OK to close the Advanced proxy setup screen.
18. Tap OK to close the New connection screen.
19. The network management screen should now list the new connection you have created in the drop-down. Tap OK to close this screen
20. Tap OK to close the connection screen.
Now you are ready to fire your favourite browser. I have tested this on PIE as well as Opera 9.5 and it works for me.
If PIE reports "Request not authorized by the WAP Gateway", you will need to change the user-agent to anything you can think of using "Advanced Config" tool (thanks to dsixda for suggesting this). I had set it to HTCP3452_Mozilla/4.0 under Advanced Config -> Internet Explorer -> User Agent Custom Base.
I think Airtel has intentionally blocked Mozilla/4.0 user-agent on WM phones. It may be that they cannot restrict Windows Mobile based phones from accessing websites on standard HTTP. On other phones I had tried, I could not get other sites to work with the same settings.
Enjoy Airtel Live for free.
Mar 23, 2009 | HTC Touch P3452 Smartphone
Wifi issues
i think there is some kind of block from the network administrator
usually you can access wifi easily with out any problems.
di u install any third party application in your phone recently??
Sep 17, 2008 | HTC Touch P3450 Smartphone
Cannot connect to internet via wireless
my phone dont want to connect to intrnet
Jul 31, 2008 | i-mate K-jam Smartphone
Wi fi connectivity
Refer to
http://www.fixya.com/support/t189947-ipaq_rx_3715_internet_settings
for a potential solution, as someone else had the same problem.
Jul 02, 2007 | HP iPAQ RX3715 Pocket PC
Motorola MC9190-GST Logo
473 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
