Question about Whirlpool Ovens
I have a whirlpool wall oven model 6AKZ152 it will not work F03 is showing on the display what does it mean and why isnt the other controls work
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Posted on Sep 29, 2007
rylee_smith
  • 8619 Answers
SOURCE: Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 15, 2010
SOURCE: whirlpool wall oven model rbs245pdq12
Adjusting circuit board settings for oven size.
Posted on Sep 21, 2011
Hi
Code F03 usually means that the oven temperature sensor is 'open circuit', that is not working at all.
The remedy is to have it replaced.
Dec 19, 2010 | Whirlpool AKZ159IX Oven
Our Whirlpool OBI C10 Oven has stopped and is displaying FO3 on the panel. I switched the supply off and on to try and reset, but to no effect. What is the cause?
Hi
Thanks for using FixYa. Error F03 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 24, 2010 | Whirlpool Ovens
The display shows F 03. The oven won't turn on and the display won't change even after switiching off at mains
An F03 code is a open sensor, shorted sensor, or bad control board. This video shows how a sensor is checked
Apr 08, 2010 | Ovens
Hi
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
F03 Displays
I bought a new oven found this one way to complex anyway. Afterall i just want to cook in it.
Regards
Ken Mc
Sep 14, 2009 | Whirlpool RBS305PDS Electric Single Oven
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
Sep 28, 2007 | Ovens
Ovens Logo
24 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
