SOURCE: thor front loading washing machine the
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
SOURCE: Model Thor1050 washing mach door stuck. How do I open?
Try bumping it. If that doesn't work, unplug the machine and then plug it back in.
Posted on Mar 14, 2010
SOURCE: Require Manual for Thor TWM 800 Washing Machine
Where can I find the instructions to my Thor WM800 front loading washing machine?
Posted on Dec 19, 2010
SOURCE: Need operting instructions for THOR
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 07, 2011
SOURCE: need to know wat the numbers on the thor washing
Methinks you could do with a manual- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
John C.
Posted on Oct 05, 2011
Nov 20, 2011 | Washing Machines
Aug 22, 2011 | Washing Machines
Sep 13, 2010 | Splendide 2100 Vented Washer-Dryer
Aug 04, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
Mar 14, 2010 | Washing Machines
Sep 20, 2009 | Whirlpool WFW9200S Front Load Washer
Aug 22, 2009 | Whirlpool WFW9200S Front Load Washer
Jul 05, 2009 | Brandt WTC0815F Top Load Washer
May 08, 2009 | Brandt WTC0815F Top Load Washer
Dec 15, 2008 | Hotpoint Aquarius WD640 Front Load...
312 people viewed this question
