Question about Bosch Coffee Makers & Espresso Machines
Siemens Coffee Machine TK54001. After 3 years of good service the machine is stuck on two simultaneously flashing buttons: STAND BY and COFFEE... WHat does it mean?
3 Suggested Answers
  • 5370 Answers
SOURCE: hi I have a problem
First unplug the machine from power outlet and let it remain in that way for 30 minutes.Then reconnect and see if this is helping.This is reset procedure.----------------- Fill tank icon flashes (red) when the removable water tank needs to be refilled. Remove the water tank, fill with water and replace it on your TASSIMO machine. ------------ Descale icon lights up (red) when your TASSIMO machine needs to be descaled. Descale your appliance in accordance with the instructions provided under "Descaling". ---------- How to Descale:-- Your TASSIMO machine has an automatic descaling program. If Descale icon lights up while the appliance is on, the descaling program must be run immediately. If the descaling process is not run as instructed, the appliance may become damaged. ---------- Descaling agents (not vinegar-based) can be obtained from various retailers or from TASSIMO or Bosch Customer Service Department at 1-877-TDISCS1 (1-877-8-771) or on www.tassimo.com. CAUTION:---Do not drink the liquids.Never interrupt the descaling program. Never use vinegar or vinegar-based products.------- Note: Only for machines with water filter It is essential to remove the filter holder with the filter cartridge before running the descaling program. ----------------- Running the descaling program.Remove the water tank from your TASSIMO machine and take the Service T DISC out. Insert it in the brewing unit with the barcode face down, and close the clamp down firmly. Prepare descaling solution (not vinegarbased) according to the manufacturer's instructions. If you cannot find an appropriate descaling agent at various retailers, it is available through TASSIMO or Bosch Customer Service Department. Replace the water tank containing the descaling solution back on the machine. Remove the cup stand and place a suitable container (min. 17 oz / 500 ml capacity) under the drink outlet. Press and hold the start/stop button for at least 3 seconds to start the descaling program.The program now proceeds automatically and Descale and O Automatic lights flash. (Duration approx. 20 minutes). The descaling solution is pumped through the appliance at intervals and then runs into the container until the water tank is almost empty. A little liquid is always left in the tank. Stand-by icon will light up after approx. 20 minutes of running descaling program. Empty the container and replace it under the drink outlet. Rinse the water tank thoroughly and fill up to the MAX mark with fresh water. Replace it back onto your TASSIMO machine. Open and close the brewing unit keeping the Service T DISC in place on the T DISC holder and press the start/stop button. The machine will rinse itself. Once one cycle is complete, press the button again repeating 4 more times. The descaling process is complete. Now open the brewing unit, remove the Service T DISC and store it in the compartment at the back of the machine.----------- Note: For machines with water filter Place the filter holder with the filter cartridge into the water tank. Your TASSIMO machine is ready for use again. ----------- But if its not possible to start the desacale or if you have not done the descalling cycle when the machine indicated to do so then the fill tank and descale light both will blink and machine will get stuck in stand by mode.In that case There is an error on the machine.The machine has to be resetted,Contact the TASSIMO or Bosch Customer Service Department at 1-877-TDISCS1 or (1-877-834-7271). -------------- Also see in the water tank.There is a float.If that float is stuck then water fill icon light will blink.With your hand release that float in water tank.Then see.If the float is release and not stuck,still the both lights blinking then yes machine is got in the stand by mode and needs resetting by the service center. ---------------------- This should help.Thanks.Helpmech.
Posted on Jan 20, 2011
  • 1833 Answers
SOURCE: I have a two year Problem
Hi, First turn off and unplug your coffee maker. Unscrew the two screw holding the outlet and remove it. you can follow the service manual for help.
Posted on May 04, 2011
When I plug in the machine all of the lights just flash and nothing else happens
unplug unit and throughly clean unit, especially the bar code reader window. Take apart the piercing nipple assembly and make sure it is not clogged either. Use the cleaning disk and descale the unit quarterly as this prevents build ups in the brewing system
Apr 07, 2014 | Braun Tassimo Espresso Machine/Coffee...
Siemens coffee maker model tk540001 brewing unit is stuck!
Hi, I am a user with the same problem but on a Siemens TK580001. Is the solution applicable 1:1 as the two models have different panels?
Jun 11, 2012 | Coffee Makers & Espresso Machines
Espresso and Longo buttons flash simultaneously and continuously
Try holding both buttons down while you turn the machine on until they stop flashing - usually about 5 seconds. This will reset the machine to its factory settings. Hope this helps.
Apr 06, 2012 | Nespresso Le Cube
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
Both the top alarm light for empty grounds in drawer and the bottom light which signals need to perform descaling are flashing when I press the brew coffee button, the middle lights for water level and...
When you press the coffee button , and the top and bottom lights are flashing, that means the grinder is either jammed or out of order. If the machine is less than 2 years old, the service center will replaced it under warranty.
Sep 14, 2010 | Saeco Odea Go
When you press the button to make coffee, it makes the noise lake to cat the coffee and nothing happen no water no nothing!do i have to go for service?
The vibrating water pressure pump is not working and it migh be stuck due to scale or damage. Howver if you hear the loud noise of the pump then the problem is the coffee solenoid valve which it might be stuck or damage.
Good Luck
Please remeber to vote for this answer
Feb 22, 2010 | Gaggia Syncrony Compact Coffee...
Kitchenaid 14 cup programable kcm534er has an error code 4 what do i do
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Their toll-free telephone number is 1-800-541-6390.
Jul 04, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
Flashing Light
Drives you nuts doesn't it? I was about to throw mine out...could never tell if it was on or off, let alone program anything....but Here is The Solution!
Hold the hour and minutes buttons down simultaneously for about 10 seconds till light stops blinking and it will reset.  I was so happy to find this info on:
http://kitchen-stuff.info/gear/Coffee_Tea_and_Espresso/Coffee_Machines/Drip_Coffee_Machines/DeLonghi_America_Inc_DeLonghi_DCR902T_Retro_Drip_Coffee_Maker_with_Timer.html
Apr 07, 2007 | DeLonghi DCR902T Coffee Maker
Control panel lights
The manual indicates this means that it is time to decalcify the machine.  After doing so, press the ON/OFF and PROG buttons at the same time for 2 seconds.   Jeff, Burbank CA
Dec 11, 2006 | DeLonghi CAFE DUO Dual Drip Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Bosch Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Donald Currie III
Level 1 Expert
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
