Question about Provo Craft Cricut Expression 2 Electronic Cutting M
My Cricut expression 2 stuck on the main screen and won't move since 6 month ago plz help and its not fare no one is helping
CricutAddict
  • 13 Answers
SOURCE: Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
Posted on Mar 25, 2010
  • 313 Answers
SOURCE: My Cricut Expression keeps turning on and off.
I have one of these machines stripped down on the bench now with this problem. I have located the fault to a power relay which is sealed but must have burnt contacts as it is not passing the power to the machine to power up. I am still looking for a source of 18 volt coil relays with 10 amp contacts to fix this one. If not I may have to modify the circuit to overcome this problem.
Posted on Jul 25, 2010
tlargent365
  • 6 Answers
SOURCE: I need a manual for a cricut expression
www.manualsonline.com/
Posted on Feb 18, 2012
chitchatmom4
SOURCE: why does my paper move out of place when the cricut expression is cutting? Is somethhing wrong with the roller bar?
I would just use a new cutting mat if the mat your using isn't sticky enough your paper will move.
Posted on Nov 03, 2012
mack9666901
SOURCE: Dials not working
My Real Dial Size doesn't work for me anymore?
Posted on Oct 15, 2015
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    Cricut machines power supplies
    18 volts is the voltage and the thing that is most critical to stop the machine burning out.
    The 'A' - amperage is the force behind the electricity, 2.0 is a sort of fairly strong person 2.5 amps is a muscle man.
    If the piece of equipment needs a muscle man to move it and you use a weaker person, it may not move quite so fast. Good analogy?
    Anyway, .5 amps is not going to make that much difference.
    Jun 26, 2016 | Cricut Expression Cutting Machine
    My cutting tool icon along with 5 or 6 other icons are grayed out. How do I get them back?
    It won't cut when it is greyed out. Try moving the image slightly on the craftroom mat or turn it on an angle
    Feb 26, 2015 | Provo Craft Cricut Expression 2 Machine
    Cricut expressions 2 pressure wheel
    You say you have a Cricut expression 2 but you say quote"...of how to reset the machine including the rolling of the dials up and down three times!" The problem I have in sorting your problem is that the Cricut expression 2 does not have wheels which work the speed, pressure and size. If you have an expression version 1 machine then there would be 3 wheels on it to adjust the speed pressure and size. Obviously if you have had the machine for 4 years it is out of warranty and I am not sure just what the person did to "fix" your problem. I do recollect a video on you tube with a similar problem however looking at the video he mentions that once it is fixed the blade housing should bounce up if you push it down, does your housing now do the same as the video. In the video Evan did he mentions at the end that the soldering of these wires may not take the first time so this may be a point to check as he mentions that it was travelling the machine that caused the wires to break in the first place. The youtube.com video I am speaking of is http://youtu.be/n7LJnfPdd08, by Evan Craftman. I am assuming that when you called cricut support you called the UK support line. I often speak with support in the USA being from New Zealand it is an overseas call however I have found them very good. If you are able to I would like to see a video of just what your machine is doing. If you dont want to post it here you could email me flohillrennie@gmail.com.
    I do feel very sad that you don't wish to try the Explore as I find it a surpurb machine. I have had my Expression version 1 since early 2009, I have added every Cricut to my family of cricuts and own 3 expression 2's and now an explore. If you had bought a computer 4 years ago and you currently took it to a repair person to get it fixed I am sure their first response would be it would be better to get a new one. Your computer boards appear to be fine maybe you need to take the video to the person who did your fixing as most people who do this sort of work would not understand how the machine runs. I hope this helps and you can get your Cricut working again. If all else fails you may be able to buy a 2nd hand one cheep and have your repair person change the carriages completly.
    Jun 13, 2014 | Cricut Expression Cutting Machine
    My Cricut Expression is not working. When i pressed the cut point on the screen all it did was a loading screen and would not cut. What should i do?
    fruchey10 you have not given me enough info to help you but if you contact me I will try to work out a solution to your problem. exactly what are you doing ie do you have images loaded onto the image queue. contact me via my website OhSoManyCrafts
    Feb 02, 2014 | Cricut Expression Cutting Machine
    My cricut wont turn on
    Hi, My cricut expression is more then 5 years old. I used it one day and the next day I would not come on (it dose Nothing at all). I brought a new power cord from cricut and still nothing. I'm unable to buy a new one Please help if you can. Thanks!!
    Jan 26, 2014 | Cricut Expression Cutting Machine
    Why does my paper move out of place when the cricut expression is cutting? Is somethhing wrong with the roller bar?
    Mar 25, 2012 | Cricut Expression Cutting Machine
    Cricut expression 2 has no power, will not turn on
    Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
    Nov 05, 2011 | Cricut Expression Cutting Machine
    Jun 10, 2009 | Provo Craft Cricut Disney Font Cartridge
    Dials not working
    You may want to try resetting your Cricut to see if that fixes the problem. To reset the Cricut machine, turn the unit off for five minutes. Roll all the dials all the way up and all the way down five times each. Turn the Cricut back on. This is the manufacturer's reset process. Good luck!
    Mar 13, 2009 | Provo Craft Cricut Disney Font Cartridge
    Provo Craft Cricut Expression 2 Electronic Cutting M Logo
    159 people viewed this question
    Top Provo Craft Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Provo Craft Office Equipment and Supply Expert? Answer questions, earn points and help others
