Question about DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker
Where do i insert the water spoot on my primadonna
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Very gently in the centre of the orrifice .
Posted on Nov 02, 2013
I have a Delonghi PrimaDonna ESAM 6600. Just recently it stopped frothing milk. To explain fully, I have outlined the sequence of the fault below and resolution steps that I have already tried.
That sounds like the spout is blocked, when the pump goes quiet it is because it has built up pressure and the solenoid is barely moving. Have a probe up the nozzle and see what happens.
Jun 29, 2015 | DeLonghi Coffee Makers & Espresso Machines
Empty circuit fill circuit insert water spout press ok
when inserted the water spout if the water is delivered,that means you have an issue with the flow meter and you have to tack it to maintain,
how ever if the message (fill circuit ) turned off after the posses of filling the circuit and when you are trying to brow coffee the message shows, that means the grinder is too fine adjust it and try ones more
Apr 12, 2015 | DeLonghi PrimaDonna S Deluxe Super...
Delonghi PrimaDonna hot water not working
First I assume your machine is not too old? if it is,maybe you need to descale the machine as limescale can build up and block the outlet. If this does not solve the problem, it might be that the element has burnt out. New Machine!!!!!
Aug 26, 2014 | DeLonghi Coffee Makers & Espresso Machines
I own a Delonghi Primadonna. The issue the water container has water either full or half full. The stern says fill water!!. Can someone please help.
There is or should be a small black square piece set in plastic in the water tank which is the float. Make sure this is freely moving up and down in its little compartment. This connects electrically to a solenoid inside the machine which tells the machine if the tank is empty. If it is moving freely then it is probably the solenoid which is at fault.
Oct 12, 2013 | Coffee Makers & Espresso Machines
When i turn the heater on its making an awful noise?
The fan could be rubbing on it's shroud. I would check that first. Ascrew could have vibrated out as well.
Oct 15, 2010 | DeLonghi Primadonna Mid-Size Heater
One spout is very slow with leaking
The spout is only a plastic with two holes, if the one is only leaking while the other is running corectly then you only need to clean it with hot water and a small brush the hole and the groove. the spoot can easily removed, or even emese it in a pot with hot water for 20 minutes then flash only water.
Jan 05, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
We have just bought a secondhand baby Gaggia and we cant get the steam to come out the frother. It is an orange coloured machine .
Propably the steam pipe is blocked from dry milk. You can use a thin steel wire insert it in the pipe from bottom. If you manage to open it a little bit and start having steam then by boiling water and leave the steam pipe imerse in it it will melt the remaining dirt and by open the stem valve then the dirt will spoot out. If not then the valve is blocked or broken.
Jan 02, 2010 | Gaggia Baby Espresso Machine
Just did a clean out of my coffee machine. Now it says insert grounds container! I do and it does nothing..could it be moisture in it? help.A
I had same problem with DeLonghi PrimaDonna. Three hours with the mentioned fan and the switch started working again.
Thank you so much.
Aug 21, 2009 | DeLonghi Coffee Makers & Espresso Machines
Milk container won't fit onto front of machine
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
May 02, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker Logo
81 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
