Question about Indesit 24 in. DI67 Free-standing Dishwasher
DI 67 S fault
Pre wash light flashing. Machine starts then stops. Filter inside blocked , water all over the floor. Will not re set and work.
  • loonybin Nov 20, 2007
    Pre wash light flashing, flooded, trips RCD, machine will not reset. What doe's the pre wash light mean when it's flashing, it doesn't tell us in the manual?
    Problem Solver:
  • 5 Answers
Try to tilt your dishwasher forwards. Be aware that water will leak out of the front. Once this is clear it should work. I paid an engineer to come and tell me this. If your machine is not completely level it causes it to over fill and after a time will not work. Good Luck
Posted on Jan 15, 2008
My Beko WMC62W washing machine has the pre-wash and the ready light flashing together how do I stop them flashing as it will not let me start the machine.
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 26, 2011 | Washing Machines
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Pre-wash light keeps flashing
The pre wash light flashing is usually an indication that the washer has failed to take in cold water, possibly due to low pressure, or restricted inlet hose.
If it does it when it is the rinse mode, then I would suggest you check the filter is not blocked.
Remove lower rear panel, remove large black hose to bottom of tub
Remove filter inside and clean., check inlet to pump as well.
Plz rate my solution.
Jan 28, 2009 | Washing Machines
Hotpoint FDW60 Flashing lights 3 and 5
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Jan 11, 2009 | Dishwashers
Candy CNA 145 stops
Found that pipe leading from the drum to the filter was blocked. Machine at first appeared to be draining but on closer inspection was not draining fast enough. Machine now working perfectly. Hope this helps anyone who may have a similar problem.
Jul 27, 2008 | Washing Machines
DI 67 Diswasher trips RCD fusebox
either the element is faulty or poss the electrical filter.
Nov 14, 2007 | Indesit 24 in. DI67 Free-standing...
Pre wash not happening
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
Jun 13, 2007 | Hotpoint WMA46 Front Load Washer
Indesit 24 in. DI67 Free-standing Dishwasher Logo
306 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
