Question about Refrigerators
Schreiber app6302 integrated fridge
Change bulb
4 Suggested Answers
  • 66 Answers
SOURCE: I have a schreiber fridge
APM6855 Built in fridge freezer If Fridge is not cooling & freezer is ok then try a defrost by switching off for 24 hrs Then switch back on. it should be OK. If this does not work it is probably the door switch faulty , this should switch on the fan when door is closed. The fan is then controlled by thermostat sensor which switches fan off/on when required.
Posted on Apr 18, 2010
caroldon
  • 17130 Answers
SOURCE: DIPLOMAT APP6302 FRIDGE
The no frost fridge has a compartment that collects the water while it keeps defrosting on a time cycle. I presume that the tray is clogged and full. you will need to access the rear to see to this. Also try to reduce the cooling on the thermostat, reduce the times you are keeping the door open. all of his will only create more frost into the coils to be defrosted. Please also see that the cooling/blowing fans in the freezer are not blocked, allow space for the air flow. Helpful I guess. Good day
Posted on Jul 05, 2010
  • 117 Answers
SOURCE: my intergrated fridge app6302 light
DOOR IS OUT OF LINE ..
causing door switch not to operate - this leaving light on even when door is closed ..
normally door drops due to heavy milk bottles etc , maybe just need a new set of hinges ..
Posted on Oct 19, 2010
Testimonial: "very helpful and thankyou"
Schreiber APM6852 Hi, I've cleaned my fridge today and defrosted the back of it, but now the light doesn't work in the fridge, I've changed the bulb, but still nothing! Have a turned the light off...
Most units use a door switch to turn the light on/off. Its usually located on the edge of the frame so the door closes on it to make/break the circuit. Switch could be bad or disconnected. Also your bulb may be bad, new doesn't not always mean good! Also look at the center contact in the bulb holder you may need to pull it up a bit for it to contact the bulb center pin. DO THAT ONLY WITH THE UNIT UNPLUGGED FROM THE HYDRO!
Aug 13, 2014 | Refrigerators
Sounds like the door has twisted
a quick fix is to place an object like a soccer ball
on the floor in front of the fridge while the door is still open
Pushing the top of the door slowly try closing it against the ball to twist the door straight
this is a trial and error aproach that does need a bit of force however it does often work and saves the alternative which is dismantling the entire door
Apr 14, 2014 | Refrigerators
Schreiber fridge
I want the fridge glass for schreiber HTI 2121 model APM6514. Where can I get it please
Jan 13, 2014 | Refrigerators
Instruction manual for Schreiber apm6121 fridge
How do you clean drain drawer if fridge is integrated into unit?
Nov 03, 2010 | Refrigerators
My intergrated fridge app6302 light fitment has completely melted why would this happen. I have taken the bulb out is this dangerous and can i get a replacement fitment
Oct 19, 2010 | Refrigerators
I have a Hotpoint HMB313I integrated fridge freezer. When I open the fridge door no light comes on. Should there be a light in the fridge? If so, could you tell me please where the light(bulb) is located...
Hi!!
The light bulb is usually located in the center top of the fridge box, you may need to get on your knees and look up to see it. They usually just screw out, in case there is a plastic cover, just squeeze it and remove it. The replacement bulb can be found at Walmart or KMar it is call Appliance Bulb.
Good Luck!! Don't forget to rate this post!!
Jul 18, 2010 | Hotpoint Refrigerators
Jun 30, 2010 | Refrigerators
I have a schreiber fridge freezer. Display is showing H for fridge, freezer is ok. Can anyone help? Thanks Anne
Nov 15, 2008 | Refrigerators
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
