Question about Panasonic Televison & Video
Panasonic cinema vision hdtv 720p has verticle lines across the screen
Slinteriors
  • 8617 Answers
SOURCE: Blue line across panasonic large screen hdtv
What is the model number of your set?
Posted on Jan 13, 2008
SOURCE: Verticle lines following the color spectrum across the screen.
B Block assy from Sony direct is about $890. It has a core value of $525 for the old part, so once you get credit for the old core, the new B Block Assy really costs you $365. Still too much, but not as bad...
Posted on May 25, 2008
  • 1779 Answers
SOURCE: panasonic cinema vision model pt47wxc43g has
Sounds like Convergence Ic's are defective. The best advice would be to contact a Svc. Co.
Posted on Feb 26, 2009
stonephoenix
  • 563 Answers
SOURCE: I have a verticle black line about 3 inches wide on my panasonic
Normally when a line appears on the screen of a plasma or LCD it indicates the TV needs repair. There are circuit boards inside the set that, if bad, will cause problems with the picture. The only troubleshooting the manufacturer will offer is to unplug the TV for 30 minutes. If that doesn't solve the issue, the unit needs service.
Call Panasonic at 800-211-7262 to see what they're willing to do for you. If you're under warranty they will service the TV for sure. If you're out of warranty they still might give you a break--they've been known to do that.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
SD Tech
  • 14553 Answers
SOURCE: how do you calibrate a rearprojection panasonic
OK, I know this set very well--if convergence in the customer menu is skewed and red or blue will not adjust in some direction, you have a convergence problem.
I can give you (post here) START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
It requires that you are able to solder etc---not real hard even if you have never done it before.
Considering you can buy the parts on Ebay for about 20 dollars if you can do it yourself or know someone who can do it for you--you can save the set and a lot of money......most shops get 300 or more for this kind of trouble.
If you want the instructions let me know and I will post them.
I can tell you the best place to get the chips--this set uses two STK-392-110 CHIPS.
Usually just both chips need to be replaced and the set adjusted.
The instructions tell you everything you will need and how to do the fix.
I composed them from my own experience and because many people here ask the same thing you did.
If you have questions etc, let me know. I am here to help people.
If this has helped you, rate this solution as I do this here for free.
Thank you for using Fixya.
SD TECH
Posted on Nov 20, 2009
Testimonial: "Super fast responder, very helpful!"
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
Why my seiki 32 in has 2 inch line going across top
on the remote look for a button called apex and push it 3 times while looking at the black part od the set.
Terry
Jan 16, 2015 | Seiki ki SE32HY10 31.5-Inch 720p 60Hz LED...
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
Jun 06, 2012 | Panasonic Televison & Video
I have RED verticle lines all the way across the screen fro top to bottom 10 minutes after I turn my Panasonic PT-52LCX65 TV on. Is there a solution?
Hello
Check and replace the main filter capacitor in the power supply section. Replace all of them in the secondary section of the power supply too. The problem is due to insufficant smoothing and regulatio fo the power supply section. If main smoothing capacitor gets value deveoped, it won't supply enough voltage to the switching section, and switching section also will go inefficient. Replace all of them. It won't cost not much. OK.
Jun 22, 2011 | Panasonic PT-52LCX65 44" HDTV
Problems with my Mitsubishi hd1080
Most likely you are looking at conversion chip problem. The replacement price on these can varry widely. It may be cheeper to look into purchasing a flat panel lcd or plasma tv.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic PT-47WX53 does not turn on
Yes, I did try to use the power button on the TV itself. That did not work too. Yes, there is blinking red light too. I searched through several sights and found out that it is an issue with the IC 4511. I could not find a place to buy the chip.
By the way, our local TV dealer asked for $400 to fix this issue. I had already spent $400 on a different repair on this TV, 6 months ago.
Any suggestion/advice would be very helpful. Thank you again for your response.
Feb 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Dec 30, 2007 | Televison & Video
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
