Question about Dehumidifiers
Dehumidifier 415 8109
I need a manual for the 415 8109 and RAM 710
Challenger dehumidifier 710 left on all night water on floor none in the tank
Maybe there is a hose connection to the pan and it is missing its cap? I have an old Sears humidifier and always had a hose on it going to the sump.
Jan 18, 2018 | Dehumidifiers
Why is it not collecting water in container?what can i do? do i need the manual?
oohn ive seen this before in some units especally on ones that are in heavy use (lots of water to remove) the drain hole inside unit drain gets stopped up with black mold (wet enviroment it grows quite well) unplug unit and some minor dissasembly of the outter case and it soon becomes obvious what the problem be , i have been somewhat sucessfull with a mild laundry bleach in a trigger sprayer to kill mold and use a pencil to poke open drain holes
I'LL bet thats your problem
Oct 20, 2014 | Dehumidifiers
Winix wdh851 service manual
The owner's manual is here: http://www.sylvane.com/media/documents/products/winix-wdh851-dehumidifier-owners-manual.pdf
but that's probably not what you want. You might try posting your specific issue that you need the service manual for. For instance a fan that won't start is a common problem for dehumidifiers and a cheap fix. If that is your issue read this: http://www.fixya.com/support/t3588983-lg_lhd65ebl_serial_603taac20984
The article is for an LG dehumidifier but the thermistor mentioned is common to most brands.
Jul 13, 2014 | Winix 50 Pint Dehumidifier WDH851
How many watts is a DE45EJ-L dehumidifier?
There is a review website that claims the unit draws 590 watts. The refrigerant this one uses is R-134a.
Haier 45 Pint Dehumidifier Review
A slightly larger unit is also available from Haier, the DE65EJ that uses R-410a, which is a more efficient refrigerant and allows the unit to be perhaps 20% more efficient. That larger unit is rated for 65 pints a day, and uses 710 watts. It is a bit heavier than the DE45EJ also.
Jul 01, 2014 | Haier Dehumidifiers
Need an Operation Manual for Delonghi DN125 Dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Jun 01, 2011 | DeLonghi DN 125 Dehumidifier
If my dehumidifier seems to be working fine( fan comes on and all buttons work) and its not picking up water anymore could there be some other reason that its not filling up? We did also fix a few leeks in...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 23, 2010 | Frigidaire FDL50R1 Dehumidifier
FDL25P1 25-Pint Portable Dehumidifier Dehumidifier: The dehumidifier is running but is not pulling any...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 18, 2010 | Frigidaire FDL25P1 Dehumidifier
Hi... I have a challenge ram 710 dehumidifier, the fan has stopped working but there is power to it, when i took it out it is all greasy and black like all the lube has seeped out... does anyone know where...
I also had exactly the same problem with my RAM170 Dehumidifier, it's a very common problem with them. The good news is, assuming the motor winding has not burnt out, then problems with the fan motor can easily be corrected. It's now over two years ago that I carried out the following procedure with the motor in my RAM 170 and it has continued to function with no further problems. Firstly take a photograph or make a drawing of the motor assemble, then fully dismantle it. Thoroughly clean all the black (gungy) mess off the spindle and bearings, WD40 is good for this. Next apply a small amount of light grade oil (it must be thin oil) such as Singer Sewing Machine oil (about 60 pence for a small can) to the spindle and bearings, then fully reassemble. When assembled the motor should spin freely.
Feb 15, 2010 | Dehumidifiers
Gold Star HD504EL Dehumidifier owner's manual
Try going to the manufacturer's web site. Hook into Support , or Downloads. Then look for the operating manuaal. Or, in their site, Search for the manual. This often works.
Sep 27, 2008 | Goldstar DH504EL Dehumidifier
Dehumidifiers Logo
104 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
