Question about Garden
460 Rancher hasn't got enough oil from day 1 ! HOW can i fix this
  • 2,239 Answers
Pretty common to model, there was a latter oil pick up hose to stop it kinking part no, 537261402, and a latter filter which was more open part no. 505315181, it is possible to alter the throw of the pump by increaseing the angle on the back of the pump shaft, however this is not so easy you have to grind the shaft, it is easy to over do it and icrease the flow too much.
Posted on Oct 22, 2013
dontbother10
  • 2220 Answers
SOURCE: what is the ratio of oil and gas mixture for
Find an Operators and an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel ratio 50:1 = 1gal premium/2.6oz quality 2-cycle engine oil
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Nov 07, 2009
dontbother10
  • 2220 Answers
SOURCE: no oil to bar or very little, have parts, need
HusqvarnaUSA.com
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 14, 2010
  • 12 Answers
SOURCE: I have a new hasky 460 rancher stalls when given
If it stumbles at full throttle, the fast (high) idle screw is set too rich. Using your owner's manual, locate the high idle adjustment and back it off in very very small increments. Do this until the saw will run wide open without stumbling.
Posted on Jun 13, 2010
  • 2239 Answers
SOURCE: husquvarna 460 rancher 20" bar all new including
The normal reason for a saw to cut to the left, or right is because the cutters have been sharpened more on side than the other, they are now longer on one side, this then sends the cut off to that side. Measure the cutter lenghts, take the correct file and shorten the longer cutters
Posted on Mar 06, 2011
Testimonial: "Thank you it was a new chain sharpened once"
  • 95 Answers
SOURCE: New 460 rancher 20" bar and chain cuts at an
It sounds like your chain is just dull.Or might not be sharpened right.This usually happens when the chain is getting dull.
Posted on Mar 09, 2011
Testimonial: "I think you may be correct, although the bar and chain are new it appears that one side of the chain has been sharpened at adifferent angle. Regards "
High and low setting for hasqvanna 460
Husqvarna 460 Rancher Manuals
www.manualslib.com > Brands > Husqvarna Manuals > Chainsaw
Manuals and User Guides for Husqvarna 460 Rancher. We have 3 Husqvarna 460 Rancher manuals available for free PDF download: Operator's Manual ...
Jul 23, 2015 | Husqvarna 20" 60cc Rancher Chain Saw 460
Rancher 460 Chain loose
If you have run out of adjustment there are a number of reasons, wrong drive link count of the chain ( too long ). The chain has stretched due to the machine not oiling correctly, or the tentioner has stripped the thread and is not moving forwaed.
Jun 29, 2012 | Husqvarna 20" 60cc Rancher Chain Saw 460
SAW AND BLADE SMOKING
Not enough oil getting to the chain, check the oil flow, hold the tip of the bar close to a tree stump rev the saw, you should see a good line of oil on the stump srayed from the end of the bar, if not the machine is not oiling, drain the oil tank, fill with a suitable cleaning fluid, give it a good rinse out, and try again.
Jul 18, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
On the 460 rancher does the chain oil tank have a breather pipie? and how easy is it to replace all the pipes. as it seems to block up untill i open the tank and air gets in
The breather sits in the bar pad, it is a sintered plug that covers a duck bill valle, you would need to screw a self tapper into the plug so as to pull it out, this will of course desroy the breather and would need replacing
Jul 07, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Hi, my name is chris and i own a 460 rancher. just today the saw started to bog down when a load was added to it. seems to run at max rpm with no load however once touching the wood it will start to bog...
Hi Chris,
Check the air filter is clean and the choke plate is working ok.
Ensure the chain is sharp.
Check the chain isn't damaged and dragging in the guide bar.
A blocked muffler/silencer can cause loss of power.
Try screwing the "H" mixture adjustment screw in with the engine running at full power to reduce the richness of the mixture. Do this 1/4 turn at a time. Ensure you count the number of turns so you can get back to where you started.
Apr 28, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Mar 09, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
I have a 460 rancher brand new and it cuts crooked it cuts to the left. i have tried several chains. it has a 20" bar. any ideas?
The chain may have the procedure but the driver plate is worn out - what happens when you are not attached to the chain lubrication oil lubrication channels or if the chain is about or when the pump is not working.
Mar 06, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
I have a Husqvarna 460. I have had to get my oiler replaced twice now. It just stops working. Is this a common problem with the 460? What is the reason why they stop working?
It sure is, there have been issues with the pick up pipe kinking, the filter being to fine to allow oil flow, it is possible to increase oil flow by increasing the angle on the pump shat, but this is a dealer mod.
Oct 07, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
What is the mix ratio for the Husqvarna 460 x-torq
I gallon of premium fuel to 2.6 ounces of quality 2-cycle oil is 50:1 and what Husqvarna says in the manual. You can download a current OM here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
How do you like the your 460? I almost bought 1 myself (opted for 359). More questions or if you need more help please reply below. HTH
Lou
Feb 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher will not produce oil for the chain. Oil pump replacement? Need repair manual or parts breakdown. Thanks Warren
Also make sure that where the oil is pumped against the side of the bar that the oil port (little hole) that feeds oil into the bar's slot is clear. Mine would go through a tank of oil with each tank of gas, but the chain wasn't getting oiled until I cleaned out this little hole.
Jun 29, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
