Question about Yamaha HTR-5830 Receiver
Hi, I have a Yamaha HTR 5930. First of all I have to say that I'm expert at all and I have 2 question: 1) In the back of the subwoofer there are 2 RCA connection, but in the user manual it looks like only 1 connection via RCA is needed: Which one? Why tehre are 2 jack connections? 2) I'd like to use the Subwoofer with the function auto stand-by when Home theatre is switched off, but after some minutes in this mode the subwoofer switchs off (red light on top). Could you help me to configure everythink in the best way. Thanks a lot for your support , Stefano
    Top Expert:
  • Yamaha Master
  • 49,099 Answers
You are the EXPERT so you say FIGURE IT OUT
Posted on May 16, 2017
  • 36 Answers
SOURCE: Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
Posted on Jan 01, 2008
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
  • 1114 Answers
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Posted on Jun 26, 2009
  • 150 Answers
SOURCE: I have a rca no rtd250 impedance 12 ohms
The Yamaha can only drive powered subwoofers. Make sure that the RTD250 has it's own amplifier built in, you won't be able to easily run it off the yamaha if it doesn't.( the powered subwoofer will have a mains cord to power if it's correct) If it doesn't have a amp built in, easiest weay is to buy a cheap powered sub.
Is the RTD 250 the sub fromthe RCA home theatre pack?
Posted on Jan 14, 2010
How do I reset my Yamaha HTR-5930 receiver back to the manufacturers settings
Hello there
A combination of 'standby' and 'straight' buttons
You follow the procedure on page 65 of the user guide
available to download here if you have lost it.
Sep 24, 2014 | Yamaha HTR 5930 - AV receiver - 5.1...
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I am trying to figure out how to connect my ipod to my Yamaha htr-5930. Can I do that through the headphone jack, or through the aux jack? Is there anyway I can do this? Thanks! is where...
Use a 3.5 mm to 2Male RCA cable. Plug this into an AUX or CD input in the back. Adjust the volume on the iPod as well as the master volume to balance out the sound. The headphone on the receiver is output only.
Apr 12, 2011 | Yamaha HTR-5930 Receiver
I have a Yamaha HTR-5930 Home Theater Sys. Somehow, I've managed to lose my right channel when watching T.V. (dish network), but when my son plays with the XBox, he gets full surround stereo. Any ideas?
The XBox is probably hooked up separately to the amplifier, try cycling the inputs on the amplifier. If that doesn't work replace the cbale between your amplifier and tv.
Nov 19, 2010 | Yamaha HTR-5930 Receiver
makesure the ampis set on dolby prologic 3 channel
Jan 02, 2009 | Yamaha HTR-5930 Receiver
Problem w/ 5 ch mode
Hi, maybe you are not feeding a 5 channel program.
Use built-in test tone to check if all speakers are wired and working correctly.
Nov 20, 2008 | Yamaha HTR-5930 Receiver
No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
Jun 30, 2008 | Yamaha HTR-5930 Receiver
Yamaha htr 5930
I think you have to adjust balance.
Page 22 of user's manual explains how to do it:
May 24, 2008 | Yamaha HTR-5930 Receiver
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
Feb 17, 2008 | Yamaha HTR-5930 Receiver
Yamaha HTR-5830 Receiver Logo
75 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
