Question about Hamilton Beach BrewStation 47224 Coffee Maker
I have Siemens TK 52... coffee machine and after 3 years of working the problem emerged... The COFFEE button and Stand by/ON button started blinking simultaneously.... After switching the machine off and on again, the same appears.. the blinking coffee and standby buttons...... PSe assist to identify what could be the problem... I suspect that maybe grinder unit is stuck... ?!
SOURCE: Leaks when dispensing
I think I just pulled off an effective fix on mine... went from leaking all over the counter to no leaks in the last three pots.. not sure if we have the same model.. in fact I don't even know what model I have... it's a plain white unit with a singe button. Anyway, here's what I did:
  • Remove the bucket
  • Turn bucket over
  • On my unit, the bucket itself is mounted inside of the white outer trim, and the assembly is held together by four recessed phillips screws. Remove those four screws and seperate the bucket from the outer shell.
  • Reach into the bucket and pull the rubber gasket seal from the dispenser.
  • On the bottom of the bucket, raise the dispenser lever until the spring pops out.
  • Stretch the spring a bit.. not too much, you want to be able to put it back!
  • Clean the gasket seal and the gasket seating surface.
  • Put it all back together :)
The stretched spring causes the gasket to seal more tightly than it did before, and in my case, stopped the leaks.
Posted on Nov 28, 2007
siawolf
  • 749 Answers
SOURCE: auto shutoff
some of these coffee makers have feed tubes, which can be seen in the rear water reservoir, that feed the hot water to the grounds. some of these tubes collapse when the boiling water passes through them , then kink , causing the water to stop flowing untill it either cools or is straightened. To check and see if this is occuring.. look in the back reservoir, if there's a tube running through it, note how soft it gets as it starts to brew.. be careful the water inside the tube is hot.. This indentify why it stops brewing partway though..
Posted on Sep 26, 2008
SOURCE: coffee maker won't turn off with off button
try unpluging it and then reprogram it
Posted on Dec 21, 2008
SOURCE: Leaking Coffeepot
it is the rubber seal it just pulls off push new one on
Posted on Jun 14, 2009
  • 10 Answers
SOURCE: My stay or go coffee maker. When I try to make a
Try cleaning out the water system, it may need to be descaled, buy the descaler from the supermarket, follow instructions, make sure machine is well flushed out with clean water after cleaning operation.
Posted on Jul 07, 2009
User manual tk 68 e in english
Here is the manual for your coffee machine, please put it in the correct category next time.
Download manual or user guide for the product SIEMENS TK68E570 Coffee maker
Aug 13, 2014 | Computers & Internet
SIEMENS TK 68 E FILL UP PIPE SYS MESSAGE ON SCREEN
Mar 06, 2011 | Coffee Makers & Espresso Machines
How do you set the time as well as the timer? I have looked but can not find the manual.
Good Afternoon,
Programming Your Coffee Machine
• Plug in your appliance: the display will light up briefly in blue, blink "8888" and then remain
fixed.
• Press the O/I button if you wish to make coffee without using the programmable mode.
• The display will light up in blue and alternately show "ON" and the current time.
• Press the O/I button to shut off the coffee machine. The display will no longer be lit.
Setting and Adjusting the Clock
• The machine must be "off".
• Press and hold the prog button (o) for 3 seconds: the hours will blink "88 _ _".
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink" XX 88".
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink "prog" for about 1 second, followed
by "8888".
• Press the prog button briefly: the hours will blink "88 _ _".
• Press the prog button briefly: the minutes will blink "XX 88".
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a " ".
• Press the h/min button to cancel the programming.
Click the link below for the maunal:
http://www.krupsusa.com/NR/rdonlyres/A50B1840-2CD9-44C1-87E8-260B92D96D3A/7244/FME124_FMF345_usa.pdf
Hope this helps!
zeppelinx12
Feb 23, 2011 | Krups FME2 Coffee Maker
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
The small and large cup buttons are alternatly
I had the same problem and was told it needed to be repaired by Nespresso and the cost would be 115 euros.
Jan 07, 2010 | Nespresso Le Cube C185 Espresso Machine &...
Coffee won't brew - lights turn on - clock works - clicks little.
2 years old I would pitch and buy a new one.
Cleaning generally won't help a machine that does not work.
Heating element has probably burned out.
(I am not talking about the heating pad for the carafe!)
For future reference for all the coffee drinkers out there:
Simple quick way to clean a drip coffee maker is use Vinegar.
Let it brew through the system as you would water.
Discard and run fresh water through the system to clear out the vinegar residue left behind. (Make SURE the system has cooled first before running the fresh water through!)
For those that have hard water and the coffee tastes funny.
Try a small pinch of salt in the filter basket ON top of the coffee grounds. This will soften the water and hopefully take the bitter taste away.
Guess it is possible large enough calcium deposits could block the hole in the holding tank to prevent the water from percolating to the filter basket. You may wish to check this before tossing. Last minute thought before pushing the post button.
Oct 04, 2009 | Mr. Coffee TFTX85 Coffee Maker
I have a Turmix TX 150 Nespresso machine which blinks regularly when turned on, but after a while starts to blink in groups of three fast blinks - and I cannot press the button(s) to make water come...
Did their suggestions work? I also bought Turmix TX 150 Nespresso machine at http://allbestcoffeemakers.com and it's still in good condition and doesn't even have problems like this. But just in case, these answers will surely help me.
Mar 28, 2009 | Coffee Makers & Espresso Machines
Coffee pot warmer is not working
I called Cuisinarts repair center and they had me set my auto off button. It had been set to 0 so it shut off as soon as it started brewing. If you turn the switch to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. Then when you stop hitting it it will remain at that time after you brew your coffee. If that doesn't work you can call the help line at 800-726-0190, just give them your model number and serial number, the device carries a 3 year warentee
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
"water pipe empty" icon will not disappear from display screen 3, cannot brew coffee, first use - second machine to have this problem
I have a Siemens surpresso S40 with the same problem.
Try to fill the tank with hot water. I dont't know why but it solved the problem for me.
Jul 11, 2007 | Bosch Benvenuto B20 Espresso & Coffee...
Hamilton Beach BrewStation 47224 Coffee Maker Logo
212 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
