How do you change the heads on Quantum portable spinning massager? I can't get it to come apart to change the heads.
Henry hoover airo brush not working
yes, it probably is stretched.
Jan 07, 2014 | Vacuums
What is a standard massage chair?
A standard massage chair is a chair that's the patient sits on while getting a massage. These chairs have an ergonomic design. Unlike mechanical massage chairs, they are lightweight and portable.
Sep 09, 2012 | Furniture
Are there more than one type of portable massage table?
The simple answer is, yes lots! Depending on budget and features, you can really have a wide choice of portable massage tables. This link is for a site that sells a wide range of tables. i like their stuff.
http://www.bestmassage.com/portable-massage-tables.html
Aug 14, 2012 | Furniture
Remington vigoro plus (massager) still vibrates but not only the inside of it makes vibrations and i can hear something rattling inside, how do I fix this?
Poke out the four rubber lugs covering the four screws in the massage head. Remove all 4 screws and remove plastic cover. Replace round spinning weight that will have come off the spindle. Replace cover and screws. Should now work.
Jul 03, 2012 | Cars & Trucks
Fan is spinning opposite way
there should be like a switch to change direction of fan , if not then you need to change the wire connection , try that , AJ
Aug 13, 2009 | Ellington ROC52ALUM3LKRCR2 Rocket Ceiling...
Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Feb 23, 2009 | Homedics PA-4H Programmable Percussion...
Holding question
First, select a wide massage area, and use the roller surface. Slowly movethe head of the massager over the massage area in big, wide circles. Then,for areas of soreness or stiffness, change the massager to the proper mode (Some massagers have two levels) . Push down on these massage areas for about 5 to 7 seconds for eachsore spot. Finish with the roller surface again, moving the head around theextended massage area in large, uniform circles.
Aug 27, 2008 | Jobri Dolphin Handheld Massager
Massager support
Keep the massager still on the one spot for approximately 30 seconds then move it onto the next part that needs massaging
Aug 27, 2008 | Human Touch Back Pad Massager with Heat...
Fan Fail Erorr Fan:15 on m1500 Quantum DTL.
Replace broken fan, but before you do that open up your computer while it's running, and make sure all of the fan connectors are snug.
Jun 18, 2008 | Quantum M1500 (m1-2/21-s6l) Super DLT Tape...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
