Question about Behringer Xenyx 1222 FX 12 Input mixer
Left hand channel down 1222fx - Behringer Xenyx 1222 FX 12 Input mixer
  • 93 Answers
Switch all cables from the working side to the non-working side as well. This is to make certain that there is a signal going to that channel first.
Posted on Oct 26, 2014
    Champion:
  • 219 Answers
Check and clean and plug/unplug the insert jacks. Luck.
Posted on Apr 28, 2014
Hi i have a rotel ra-610 amplifier and am having intermitent static on the right hand channel only how do igo about fixing it?
I would prod and poke the channel with an insulated screwdriver this will cause buzz sounds. This should find the cause of the problem. Remember that the left hand channel is identical so you can compare the right with the left. For example if you get a weird buzz on the right when you touch it, but not on the left at the same point you might have found the faulty part.
Don't go near the power supply section as it's nothing to do with that the fault.
Sep 29, 2014 | Audio Players & Recorders
BEHRINGER XENYX-1222FX V1000 DPM5M UB-SPSU2 SCH
Hi,I was jamming yesterday and while playing not very loud the mixer went off and never worked again,also cut out the stereo amps I was using to power big speakers,been using it for about 5 hours one a week for last few months with no probs,Q:is there a fuse inside that may have blown? There was a 3amp in the normal plug which stated 5amp but worked fine for ages,I replaced it with another 3amp seeing I didn't have a 5 amp but no power,have you any ideas what to do because I need this working quick and can't afford another one,it's a behringer xenyx 1222fx mixer. Any help would be amazing Thanks Mike
Mar 09, 2012 | Behringer XENYX 1222FX MIX BOARD
In the left hand corner of my tv it says k 42rtw 111 and cannot find any of my channels?? I do not have a manual as i bought it second hand, hope someone can help???
You are in diagnostic mode. Switch off, then switch on again while holding down the Menu and Volume buttons near the on-off switch.
Sep 18, 2011 | Sharp Aquos LC42XD1E 42 in. LCD TV
Im try'n to hook a ''Duel fex pro'' multiband sound enhancement processor model ex 220, to my berhinger xenyx 1222fx mixer?
Use four (4) TRS cables. Connect from the
AUX "send" (left and right) to the input of the effects unit with two of the cables. Use the other two cables to connect from teh effects out jacks to the AUX "returns" left and right.
Mar 23, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
Can't change channel of a Motorola Visar Handie-Talkie FM Radio Model: H05RDD9AA4DN It seems that this radio operates in only one channel and I need to be able to chanmge channels. However everything else...
The Visar has a channel lock feature. If you hold down the two channel buttons at the same time, it will do one of two things depending on the settings. Either the channel will lock, or the channel numbers in the LCD will flip.
If you press the channel button and the "popples" "pop" (for lack of a better word) then the channel selection buttons re most likely OK. To fix it you just press both channel buttons at the same time for about 5 seconds. It will beep and you should be able to change the channels. If not, then it needs to be repaired.
Sep 17, 2009 | Motorola Radio Communications
I am having trouble clearing out old frequences in my bc80xlt uniden bearcat 50 channel scanner. Any sugestions?
hi marie , follow these instructions carfully ,
1. Place the scanner on it's back on a hard surface with it turned "OFF".
2. Press down and hold down the following keys with your left hand. (MANUAL), (2) and (9)
3. While holding down these buttons, use your other hand to turn the scanner power "ON". Continue to hold all the buttons down until you hear a "click" and all the channels are cleared to 000.0000.
hope thats a fix ya .
Jan 03, 2009 | Uniden BC80XLT Handheld Scanner
Onkyo TX-SR 605 shuts of when i connect left front speaker
when i connect left front speaker it's shuts down .
That is probably due to protection caused by either
DC or over current. This means your troubleshooting is not complete.
Preform these steps.
Download SR605 service manual.
(a)unplug the amp.
(b)Connect left speaker (c)remove the vertically installed pre-amp board.
See this:
How to do?
1.Unplug the amp.
2.Remove the metal cover.
3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
4.Remove this long vertically installed board mounted by 2 screws.
5.With 2 screws removed, just pulling this board out and hold it with one hand.
(d)Plug the amp and switch it on.
(e)If your amp stays ON forever, the problem is from this long board.
(f)If switch off at once, the problem is from power amp board.
Try the above- mentioned steps to confirm DC or over-
current in left channel.
(g)For DC protection, replace ALL components on left channel of the vertical board.
(h)For over-curremt protection, replace ALL components on left channel.
Replacing ALL components on a faulty channel do not cost you too much.
Feb 13, 2018 | Onkyo TX-SR804 7.1 Channels Receiver
XENYX 1222FX Mixer
I've had the same problem. It just is like the tracks mix up with each other. It's pretty irritation when you come to the mixing process. You just can't mix track where the first one for example actually is some song. But you also got some guitar from track 2 on it and the guitar track has got track 3 and 4 on it and so on and so on.
How do you fix that problem
May 22, 2008 | Behringer Dual Engine 24 Bit Multieffects...
Left Front Channel Goes in and Out
left channel there is a problem use a tester to locate the bad transistor
Sep 16, 2007 | Alpine MRV-F357 Car Audio Amplifier
Behringer Xenyx 1222 FX 12 Input mixer Logo
196 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
