Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
Exterior lights blink, ice door opens and closes on own?
All the exterior lights were blinking, and the ice door was opening and closing on it's own. I reset the power and now the ice and water don't work. What do you think?
  • 447 Answers
Im honing my psychic powers here, it a french door bottom freezer right?? Its built by samsung and the High Voltage board has failed. Had the same problem with one here
Posted on Sep 29, 2007
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
Garage door light blinks but doesn't stay on
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
I have a liftmaster Model 1240. Door will open by remote or wall opener. The door will only close while holding wall opener button down. If i try and close via remote, light starts blinking and door...
The only thing that will cause the main light to flash 10 times and the door to reverse to the open position is a sensor problem. Make sure the light on each sensor is on and not flickering ever so slightly. Make sure they are not moving when the door starts to close. Lights on sensors should not blink. One light should stay on constantly and the other sensors light should go off when you block the sensors.
Jan 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2hp garage door opener (HBW0777 year 1994). It won't close and goes back while blinking 8 or 9 times. Transmitting sensor (red light) is blinking 3 times (even i hold the two sensor...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have to hold down the wall mounted opener the entire time that the door is closing. The remote will not close the door. They both open the door fine.
Look at the back of the opener, the LED light blinks. Count how many blinks, then go to the troubleshooting guide to find the fault.
Jun 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Door will not close. led blinking 5 times
Is your door open or closed? If you release the door is it easy to open and close manually? Does the opener run with the door released?
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Blinking light in refrigerator
I think that's the light letting you know the door is open so it won't drop ice. When I held in the catch on the left side (as if the door was closed) the red light went off for me.
Jun 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
182 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
