Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Replace rubber seal on my zanussi was...
By sashsash on Sep 28, 2007
What is the trick to replacing a rubber seal on my washing machine?
It has a plastic clip fixing the seal on the outside and a metal spring fixing it on the inside.
Do I need to remove any parts first to fit the seal, I tried without and it seem to me that you need 4 hands to hold things in place!!
Thanks for any assistance
Same Problem
Mar 31, 2008
-   when you remove the door seal can you access anything that may have gone throught the drum such as a wire out of a bra?-   starz1-1
Best Solution
posted on Sep 28, 2007
Very Helpful)
barnsleymick
Rank: Guru
Rating: 86%, 378 votes
well it is a lot easier with 4 hands, i have fitted plenty and still find it easier with help although it can be done with one person,
undo the clip on the outside of the machine round the door rim, and the other end of the door seal is a thin spring band, this just pulls off with the door seal, fitting is a reversal of removal,
locate the lip into the drum outer lip, then (yes with 4 hands) stretch and fit the spring, it does fit, (it came off remember), then fit the front lip and the wire band at the front,
check for correct fit and leaks before running machine properly
best of luck, if i have helped please rate me
Comments:
Sep 28, 2007
- sorry i forgot to explain, work on the door seal through the doorway, you do not need to remove the lid etc, just open the door,
remove plug from power supply and work safe
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Apr 06, 2008
Somewhat Helpful)
pole
Rank: Apprentice
Rating: 76%, 3 votes
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Was this helpful?
Yes
No
Solution #3
posted on Jun 15, 2008
Very Helpful)
anon1245678
Rank: Apprentice
Rating: 100%, 1 votes
Found it impossible. After 30min I tried the washing up liquid trick and I got the rubber seal on in 1 min. Getting the spring on was another story, but managed in the end.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
elite oasis is that a quaitly machine
Answer
please could you tell me what model stacking bracket i need to stack a VT00P tumble drier on a WF... (More)
Answer
Hoover hw 5513 W leaking when drying, leak is from the front underneath
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
