Xerox document centre 285
Fault code u4-6
SOURCE: fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Posted on Sep 04, 2008
komguy
  • 2306 Answers
SOURCE: Where can i find Xerox Document Centre C400
you might try for help at www.partsdrop.com
Posted on Jul 16, 2009
  • 11 Answers
SOURCE: My Xerox Document Centre 265ST just stopped
turn it off completely unplug it. open up all doors and trays....turn it on with everything open if you still get the error you are going to have to call in a tech if it starts up . start closing things till you get to when that errror comes up then repost and ill look up an answer for you. i work for xerox
Posted on Dec 17, 2009
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
  • 33 Answers
SOURCE: for document centre c250 fuji
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Posted on Sep 08, 2010
Xerox fault codes
Fixya just copies and paste answers to all kinds of questions in it's answers. It is completely fake and nothing but a ad site.
May 15, 2014 | Office Equipment & Supplies
I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Jan 16, 2011 | Xerox Office Equipment & Supplies
Eror code 005 285
It is a document feeder problem.
A broken plastic sector gear causing the nudger roll not to drop to feed the documents.
Aug 31, 2010 | Xerox WorkCentre Pro 123 Copier
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
Xerox Document Centre 230st need new hard drive?
N7-4 and N711 indicate the network or as it is called the ESS hard drive has failed.
Feb 12, 2010 | Xerox Document Centre 265ST Printer
My Xerox Document Centre 265ST just stopped working and a message: Copier is not available Printer Fault please call for assistance I cannot access tools or anything else.
Dec 14, 2009 | Xerox Document Centre 265ST Printer
16 people viewed this question
jasbo
jasbo
