Question about Kodak EasyShare P850 Digital Camera
Flash door won't stay up - Kodak EasyShare P850 Digital Camera
Directional signals won't flash on a 1992 Buick century
Have you checked or replaced the flasher unit ?
Are all of the bulbs front and rear coming on ?
Jan 29, 2013 | 1992 Buick Century
High beam lights flash, but won't stay on.Perhaps a blown fuse?
check the looseness between bulb and connector. blown fuse, lights are totally out.
Aug 17, 2012 | Cadillac Brougham Cars & Trucks
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Door springs
If the door won't stay shut the issue is with the door catch not the door springs, But if you want to know where the door springs are you need to remove the outer cabinet of the dishwasher and you will see them on the lower sides.
Mar 04, 2012 | Zanussi Dishwashers
Took radio out now truck wont start.security light stays on,won't flash at all. tried deactivating passlock can't, also domelight,hd lights,l/door lock, keyless kemote not working. all this fr
Ypur security system is armed, if you was try unlock procedure from owners manual and wont work, its possible that you will need visit your dealer to reprogramming.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 24, 2012 | 2002 Chevrolet Silverado 1500
Doors won?t stay up
95% of all problems with “droopy” doors can be solved simply by replacing with a set of the correct, proper struts, which we can be supplied by DMC. Unqualified persons should never attempt to adjust the torsion bar(s) as severe personal injury and extensive physical damage are possible.
May 19, 2008 | 1983 De Lorean DMC-12
Kodak EasyShare P850 Digital Camera Logo
29 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
