Question about Sony ICF-2010 AM/FM/SW Radio
Service sony icf2001d
Display to be changed
Sony icf2001d
Perhaps this could be of any help for your camera, Sorry Radio.
link to schematic and manual from Stephan
Nov 14, 2013 | Sony Cameras
My K850i sony ericsson when you turn on, no light,no display in the screen,but keypad light is ok..pls give me a diagram to solve my problem thanks.
In that case if you can receive the call then there is display Problem you should change your display,
If your not receive any calls then please renew the Phone Software
Both Can be done only in Sony Ericsson service center Please Visit your nearest Sony Ericsson Service center they will provide you solution.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 17, 2011 | Sony Ericsson K850i Mobile Phone
Screen for a VGC VA1
of course you can change the display screen alone no problem in that... but am sure sony i think sony service may take a lot of money from you for that.. better try going to any other notebook service shops ..getting less cost...:)
Jul 26, 2010 | Sony VAIO VGC-VA10G (027242685789) PC...
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Sony cyber-shot 7.2/display screen is black and won't take new pictures.
you will have to go for change of display screen at a sony service centre.
May 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Erricson z550i Phone display not switching on!!!
in most cases the fibre ribbon gets worn out.
you can try a local cellphone repair shop, or sony service if you can afford it.
the ribbon needs to be replaced.
Jan 15, 2009 | Sony Ericsson Z550i Cellular Phone
White Display on Screen
I fixed the camera myself as follows:
1. Hold camera firmly in left hand
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
It worked, now the LCD is working again for free.
Guess I don't need to pay Sony $111.00 for repair service.
Best Regards .
M.R.Mohajeri - I.R.Iran
Sep 07, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Fuji FinePix S5000 - Display has turned pink!
4/8/08 FOR ALL CCD SENSOR'S MFG by Sony: Found the answer. Sony Repair service is fixing for free any CCD sensor problems on "any" camera that had a "Sony Manufactured CCD sensor". I have now called the service center and they sent me a UPS Return label so I can send my camera in for "free" repair. This is good news!!! I can't remember the site I was on but they listed all brands that had the Sony mfg. CCD sensors in them. So call the Sony Repair Center to find out if your camera has the Sony CCD sensor in it. This was an error in the manufacturing process and they are standing good for this.
Mar 21, 2008 | Fuji FinePix S5000 Digital Camera
Sony cybershot dscp73 view screen
Good Day, LCD display is defective, pls contact nearest service center, no longer user serviceable, still u can use it using optical viewfinder, but you can no longer change settings, cause infos are displayed on the LCD screen. Thanks
Aug 27, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony ICF-2010 AM/FM/SW Radio Logo
37 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
