Question about Irons
I have a laurastar g4 and it does not steam and the water does not go down
4 Suggested Answers
  • 4088 Answers
SOURCE: I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
Posted on Aug 01, 2009
SOURCE: my new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Posted on Feb 16, 2010
ercupa190
  • 12223 Answers
SOURCE: My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Posted on Nov 15, 2012
I have a new steam iron. I cannot uwe tab water because my house water is softned. What kind of water should i use?
any distilled water will do even if its bottled distilled water (even boiled water will do after its cooled down to avoid damaging the steam iron)
Dec 05, 2016 | Irons
How can i dismantle a laurastar s4 iron?
not really-- use the correct iron cleaner and if that doesn't work, the damage done dismantling the iron will require a new unit any way
May 11, 2016 | Irons
I have a lauraStar Magic Evolution and Steam is escaping around the filling cap. Alot What do I need to do
rubber fittings destroyed in internal compartment,ervice by expert professional
Jan 12, 2015 | Irons
I have had a laurastar iron bought from John Lewis on the. 16/01/10, it has just exploded on me, please let me know if I Can get in touch with someone to repair it ? I live in glasgow, thank you look
cannot look into your wallet ...but i would just get a new one or secondhand these things are so sensitive with their water connections once you take it apart you cannot get it together again without leaking...
Nov 11, 2014 | Irons
Nov 14, 2012 | Irons
Lost steam pressure
see this causes and fix it.God bless you
Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents.
  • 3 Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron.
  • 4 Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone
    Sep 23, 2012 | Tefal UltraGlide Easycord FV4256 Iron
    No steam
    What you need to do is clean out the steam orifice. (The tiny hole the steam comes out) When water is turned to steam it leaves behind mineral deposits, (Iron, Calcium) Especially if you have "hard" water in your area. Here's what you do. Add some CLR, (Calcium,Lime Remover) to the water you put in the iron, let it sit a while, laying flat, then drain the water out. You want to get the nozzle, to, holding the iron upside down, try to immerse the steam nozzle for a couple of seconds in the CLR or drip some directly on it. You can buy this product in most stores. It works well and fast. Dip your showerhead in it too, you'll be suprised at how it improves water flow. It is safe as long as you follow the instructions.
    Apr 06, 2010 | Rowenta DG-920 Iron
    My new laurastar steamer is not producing steam at
    Nov 13, 2009 | Irons
    Aug 01, 2009 | Hamilton Beach Steam Excel 14770 Iron
    Won't steam
    The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
    The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
    Nov 02, 2007 | Toastmaster 3302 Iron
    Irons Logo
    21 people viewed this question
    Top Irons Experts
    Are you an Iron Expert? Answer questions, earn points and help others
