Itr sounds like a failing ignition module, or incorrect trigger gap
Gentrax 4.4 inverter generator. Problem: no spark, after many hours of testing and replacing the coil, the front control panel, as the ignition module is in resin. the final thing was the crank position magnetic sensor and it is OK now after five weeks trying to get parts.
I'm a mechanic and have checked oil fuel etc. Just need a diagram to work out what is at fault. thank you in advance.
" AMAROK brake servo" " BORA brake booster" " vw CC power booster" " CARAVELLE booster" " EUROVAN servo" " EOS vacuum booster" " FOX brake servo" " GOL brake booster" " GOL SPECIAL 2P booster" " GOLF servo" " JETTA power booster"
