Question about John Deere 26HP Hydrostatic 54" Riding Mower BG20559
Humming sound when ignition is turned on will not start.
Ford ka not starting
starter or solenoid is bad . hum might be fuel pump building pressure
Sep 27, 2016 | Ford Ka Cars & Trucks
Having problem starting my 98 toyota tacoma..it takes several turns in order to "catch" i noticed earlier that a humming sound comes on when i turn the key...i already replaced the battery that autozone...
The humming sound could be the fuel pump. It starts on the ignition to prime the pressure in the fuel system. It might be worth getting it checked as that could be starving the system of fuel.
Jan 07, 2018 | 1998 Toyota Tacoma
Hyundai accent 2001 will not start all lights work radio works heater fan works battery in 3 months old when I turn the key all i hear is a humming sound for about 1 min. than nothing. weather has be
The humming would be the fuel pump coming on. It should only hum for a few seconds, then shut off.
Your problem is with the start circuit from the battery to the starter, or from the ignition switch to the starter solenoid. Check the connections at the starter (the big cable) for tightness.
Is the battery charged up enough to turn the engine over? Check by turning headlights on and observe while someone turns key to crank. If they dim a LOT, then either battery is too low, or the starter is bad and needs removing for testing. If brightness doesn't change, then the circuit from ignition switch to starter solenoid is likely not working. Check for 12 volts at the small wire to starter solenoid with key in cranking position. If you have power there, the solenoid may be bad. Remove starter for testing. If no power at solenoid in starting position, then either the ignition switch is bad or the neutral safety switch might be the problem, or the wiring from the switch to the starter solenoid is not passing current.
Good luck.
Jan 14, 2012 | Hyundai Accent Cars & Trucks
Doesnt start but turns over
there could be a couple of things that could be wrong with your car first of all saturns are bad for the ignition switchs going bad, another thing is the fuel pump could have went out they will go out without warning. The way to check the fuel pump is to go to the gas cap and remove it and put your ear down to the nozzle and have someone turn the key to the on position and listen 4 a humming sound if you dont hear no humming sound most definitely your fuel pump is out. If you do hear a humming sound your fuel pump is working like it suppose to. Then you will have to have the key switch checked by a dealer to see if the switch needs replaced. hope this helped
Jan 03, 2011 | 2003 Saturn ION
2003 BMW 325i - Car won't start. It will crank the (rrr rrr rrr)
Get a DTC scanner and see what it says...in the meantime, check that fuel pump relay and fuel pump. The humming sound is probably the heater blower motor or part of the HVAC system winding down after disconnecting from power.
Dec 16, 2009 | 2003 BMW 3 Series
GE gas dryer not turning on
Humming sound might be igniter trying to fire up but fails.
It might be eitther bad igniter or bad gas valve.
Please kindly let me know if you need more info. I am always here to help
Good Luck
Feb 01, 2009 | Dryers
John Deere 26HP Hydrostatic 54" Riding Mower BG20559 Logo
24 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
