Mf5770 Error paper jam and etc.
Mechanicam problem, printer does not take pages from box, actuall paper roll wich takes it ain't working. 2 clicks and error about paper jam every time.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
It sounds like a clutch needs replacing.
Posted on Oct 22, 2013
  • Elvis Ve?uks
    Elvis Ve?uks Oct 22, 2013
    Spring was off of paper roll. Everything would be fine, but still it prints 1 page insted of 2 pages, and after 1 priunt it just error page size, no matter what.
Dell 922 saying there is a paper jam
First try this. Turn off the printer, remove all the cartridges, drum, open all the doors and remove all the trays. Now verify that there's no actual paper jam by exploring through the inside of the printer. You can use a blower to blow any dust or pieces of paper, etc.. from the printer. Now use the manual feed and put in thicker paper several times (push in and pull out). Again reinstall and reconnect every components and boot the printer. If the actual printer's paper sensor isn't broken or stuck or twisted, this will definitely clear the paper jam message on the printer.
If the problem persists, please download this small text file and follow the instructions (click here). Open the link, click "Download Now" button, wait for 20 seconds and again click "Download File Now" link and read the instructions and follow step by step.
Good luck.
Thanks for using FixYa.
Jul 16, 2010 | Dell 922 All-In-One InkJet Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Paper jammed message won't go away
Presumably this error follows an actual paper jam (whether the culprit has admitted it or not). The following is general advice that applies to paper jams in most printers, copiers, etc.
In my experience at least 98% of paper jam errors are because a piece of paper is still caught inside the printer. The remainder are generally due to a damaged paper jam detector (usually a small plastic arm which actuates a switch inside the printer) or less commonly a failure on the PC board which senses paper jams.
Please return to point 1 and look (again) for a piece of paper jammed in the printer. If the jammed paper was torn from the printer, only a small remnant has to remain inside the printer to generate an unclearable paper jam error.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab. Occasionally a page can wrap completely around a roller and be very hard to see. Be very suspicious of any 'white' roller' - check at the ends to note if the roller is actually a different colour with a complete page wrapped around it (generally then only removable by tearing other than complete disassembly by a professional). If paper was torn you may need a pair of tweezers and some determination to remove any small paper pieces wedged inside the printer. Ensure the printer is unplugged from the wall and avoid damaging any rollers or other parts inside the printer. Always remove jammed paper by pulling it in the direction of normal travel only. On rare occasions very serious paper jams may need expert service to dismantle and reassemble the printer.
After finding and removing all paper pieces, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test.
Mar 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Paper Jam Error Message
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd22
Apr 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Paper jams and printer clicks
It's just a jam. four possible raisons: the paper is wet or very dry, the rolls in the printer are dirty, the paper is too heavy, or you didn't decollate the sheets before putting in the printer
Feb 06, 2009 | HP PhotoSmart 7260 InkJet Printer
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Paper Jam? Print quality
If the toner wipes off the printed pages, then the fuser is the problem....not hot enough or enough pressure to heat the toner to the paper. I would try to reseat the fuser...make sure it is making good electrical contact. I have also seen the paper actually wrap around the fuser roll, which would cause the same symptoms...be careful removing the paper if that has happened...the fuser roll can be easily damaged !
Jan 22, 2009 | HP LaserJet 2840 All-In-One Printer
MULTIFUNCTION JET PRINTER MODEL LEXMARK X83
You will find the solution for this on this site
Choose the Location
then type the mode number
there is a page with the solution available for this problem
http://support.lexmark.com
Dec 16, 2008 | Lexmark X1150 All-In-One InkJet Printer
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
43 people viewed this question
k24674
jasbo
jasbo
