Question about Panasonic DMR-E55 DVD Recorder
I have to identify power ic value - Panasonic DMR-E55 DVD Recorder
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
The power ICs are a known weak spot on these machines - replacements are often found on eBay, tagged with the model number. You could try this for your locale
Posted on Oct 27, 2013
The tv works fine sometimes but then the picture becomes distored on one side, jumping and fuzzy, there is no pattern to it and it is happening a lot i have reconnected all the wires but it doesnt help
Once the board warms up or the circuits works up ,t here are some components , can be active or passive that seems to go weak in the set value.
So imagine that it is the heat that changes the parameters of the board as the weak component which can be a capacitor or a IC decides to break down.
Identify the section and pin point by using a simulated heat on suspected sections which will help to identify the component .
replace suspected capacitors in this section, suspect IC's if they heat up more than required.
Mar 26, 2011 | Orion Televison & Video
Error Code 2-2. (Low Voltage Supply) What now?
That is a power supply issue and this requires a skilled person to do it.Trouble shooting in this kind of problem includes voltage measurement and resistance reading of the components/parts inside the high voltage section This is not a DIY problem but if you still want to do it yourself then I can give you some guide that you can try.
1.Check the power supply board,this board is where the power cord is connected.The common problem on this circuit are the filter capacitors .A leak and shorted capacitors always cause that kind of problem the worse is dead set.To visually identify a defective capacitor is their appearance they look to be bulging on top blown,theirs a liquid leak on the body.replace the defective capacitor if you found any.with the same rating and value..
2.Resistors -change value resistors and open resistance can cause the same problem this resistors usually near the regulator transistor.They appears as burned and overheated replace it with the same rating there is an available color code calculator of resistor in the internet click this link and key in the color of the resistor to get the value..
3. check the voltage regulator transistor if it is shorted .the first pin and second pin must not have a reverse reading..
4.Check also the two big IC marked with STK xxxx this IC are the convergence IC it controls the horizontal pin of picture..when this IC are defective this will shut down the power supply ..
The steps I mentioned must be done with a skilled personnel If you feel you can do it,well you can try or better yet bring it to the service center or call a service technician...click this link for service center
good luck hope this helps!
Feb 06, 2011 | Mitsubishi VS-60705 60" Rear Projection...
Panasonic PT-47WX49 convergence amplifiers
check R7059 and R7050
check for 2.2 ohm.
if not 2.2ohm replace them.
values are 2.2ohm at 2 watts
also look for bad soldier around all serounding resintors.
Jan 15, 2009 | Panasonic PT-47WX49 47" Rear Projection...
52 in philips help.
the large IC's on a big heat sink is where the convergence ic's will be
here is an example http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
the resistors will be on the lines of these IC's
need help identifying the resistor values?
Dec 03, 2008 | Televison & Video
I need to identify the parameters (rating) of a resistor for a Panasonic PT53WX53G projector big screen tv. It got hot so I can not see the color codes on it. This resistor glows red when TV is turned...
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
Nov 26, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Re: green convergence
Check B+ feed resistors next to IC's for visual burn damage,
identify by board location, exact value important.......
What STK part # was used ? price ? quality ?................T.
Jan 02, 2008 | Hitachi 43FDX01B TV
PT-51HX40b BP819
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Dec 08, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Tv repair
Jim, looks like you are in u1901 audio o/p IC circuit.
Could not identify R1900...there is an R1901 value== 1K,5%,1/10watt. let me know by rating this response...T.
Oct 20, 2007 | Televison & Video
Panasonic DMR-E55 DVD Recorder Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
