Question about BOSS AUDIO SYSTEMS 612ua
Wire harness boss metra - BOSS AUDIO SYSTEMS 612ua
WHAT WIRING HARNESS FOR 2007 GMC SIERRA CLASSIC TO Boss Audio 870DBI
Depends on the options in the truck. Bose/non bose, on star, etc. Www.metraonline.com
Jul 25, 2014 | Metra Ibr-whty2 Wiring Harness For Most...
IBR-WHCR2 wire harness extra yellow wire
The wire to which you refer applies power to the radio with the ignition switch in the ACC position and also maintains power flow to the memory when the radio is off. The proper connection should be apparaent from the installation instructions that came with your Metra adapter.
Dec 21, 2013 | Metra Car Stereo Wire Harness IBR WHCR2
How can I hook up subs to this stereo
If this is a FACTORY radio you need to buy an adapter for the stereo, This is an example.
RCA OUTLET plugs are connected to the amp.
This is an example. you have to get the one for your vehicle, You can also check the dealer. They might have one.
Metra radio wiring harness for VW/AUDI BOSE INTEGRATION 96-UP. FEATURES :Amplified & Boss SystemUses the Power Wire of the 70-1784; Front Speaker Output Only on Some Models20-Way Connector (Plugs into Mulit-Colored Harness in Car) with RCA Plugs
Jan 11, 2011 | Car Audio & Video
DEH-1200MP to '95 ford ranger i would like to know how to install it successfully and what sort of adapters and harsnesses i will need
Metra part numbers:
  • dash kit \ 99-5802
  • wire harness \ 70-5600
the dash kit comes with specific instructions and on the pioneer harness and metra harness just match all the colors up and your done
Jun 14, 2010 | Car Audio & Video
CAN U PLEASE TELL ME WHAT ALL WIREING HARNESSES I WILL NEED TO INSTALL THIS IN A 2007 HONDA ACCORD
You will require a wiring harness (different numbers for different manufacturers)
Metra, American international, Scoche, and more make them.
I carry metra, so the metra part numbers are as follows...
Wire Harness: 70-1721
A mounting kit is also required... 99-7862
It may be in your best interest to visit your local car audio shop - as there are several trim levels and radios for your vehicle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 27, 2009 | Pioneer AVX-P7300DVD
Stereo diagram for 1990 geo prizm
Hello stoogieprezi,
You should have gotten a plug-in harness with your new Alpine. To avoid cutting or tapping the wires on your vehicle, you need to purchase an aftermarket wiring harness. It appears that the Metra 70-1782 is the correct one for the 1990 Prizm.
Then you simply match up the wires on your Alpine harness with the Metra harness. The wiring color code for the harness is shown on the bottom left of the "description" tab and matches up with the Alpine color code on page 18 of your owners manual.
Hope this helps.
Jun 10, 2009 | Alpine CDM-9821 CD Player
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
May 21, 2009 | Pioneer DEH-1500 CD Player
Need Pinout
no - the harness is $17 or less.
Even Metra makes one (pictired above)
In my shop I charge $17 for the metra plug.
eBay it.
Metra part# AL16-0001 or al2x8-0001
CLICK HERE for an eBay auction for an original ALPINE plug. $30
CLICK HERE for an eBay auction for a $2 (shipped) one.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 29, 2009 | Alpine CDA-9831 CD Player
Factory Amp
I assume you used the correct Metra plug (70-1878) to install the radio. Ensure the blue and white wire on the Metra is attached to the blue and white wire (or solid blue) on the Sony. This will provide + turn on voltage to the factory amp.
The other good possibility is that the Metra harness has a black and a black and white set of wires both must be ground.
Lastly the Metra harness does not provide these( -) grounds, they are supplied by the braided strap . or the single wire that was attached to the back of the Jeep radio.
Jul 22, 2008 | Infinity 475A Car Audio Amplifier
BOSS AUDIO SYSTEMS 612ua Logo
26 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
