You may be able to find a replacement harness for the Boss BV9967B at an electronics store or online retailer. Some options for purchasing a replacement harness include checking with the manufacturer, contacting a Boss dealer or distributor, or searching online marketplaces such as Amazon or eBay.
You may also be able to find a universal wiring harness that can be used with the Boss BV9967B. These types of harnesses are designed to be compatible with a variety of head units and can often be used as a replacement for a specific manufacturer's harness.
It is important to make sure that you purchase a wiring harness that is compatible with the Boss BV9967B and the specific vehicle in which it will be installed. Make sure to check the fitment information and any applicable compatibility notes before making a purchase.
You will need a GM dash kit designed for 2004 Impala (see picture below)...Lower steering...Remove radio...Unplug harness and antenna...Boss wiring matches colors wire for wire in factory plug...Splice one wire at a time to matching color...Plug in antenna...However it is much easier to buy a plug-n-play harness ($25) designed for your vehicle eliminating the need to splice...The Brown wire goes to ground via switch...saailer Cost $15
You don't need a wiring harness for the radio unless you lost the one that came in the box with the radio.
You can find a wiring harness for your car here. Fit My Car That will list all the things that are compatible with your car, including aftermarket wiring harness to connect a stereo.
did the same thing no harness but went to boss webpage got the number and called said it cost 25.00 with shipping by the way on there support page is a download for there parts form order you'll need it hope this helps
Not real clear on question, but you can buy a direct fit wire harness and the wires are color coded so you don't have to cut and splice your wires on your factory harness.The harness hooks to your factory plug and you wire it to your pioneer stereo wires. Harness is about 7.99 up at most stores.
