Question about Creative Toys YACKER TRACKER
I'm having trouble fixing a 1950's Mattel yacker Larry the Lion. I have been able to fix every other type of vintage pull string toy, but Larry is hard to determine what the problem is. His o ring is intact and a different type of o-ring than all the other pull strings.
Marking on neck of doll
Imco Toy Ltd Company From Hong Kong
Usually From the Vintage Toys.
Sep 04, 2014 | Mattel Toys
How do I repair talking mechanism?
That would be a part you'd need to get directly from the manufacturer. Or better yet, get one from eBay and use it to replace the mechanism or just use it instead. Good luck!
Jul 19, 2014 | Mattel Vintage 1989 Mother Goose Says See...
I need a replacement "Feed Belt" (like a long spring) for a Bell and Howell Filmosound 302 16mm projector circa 1950
Larry Urbanski at Urbanski Film in Illinois stocks the spring belts for all brands of 16mm projectors.
Oct 17, 2013 | Bell & Howell Bell Howell Filmosound Movie...
Talking horse blaze voice box repair
You will have to remove the outside covering material to get access to the box, then open up the box (if possible) to replace the pull string. Check operation before covering up again.
Nov 19, 2012 | Vintage Toys
I have a Barbie Mattel O Phone and recently got the records that go inside however I have no instructions. I inserted batteries but it didn't work. Do these old 1960 s toys no longer work, or can they...
Yes they should work if uou inserted everything correctly. I would suggest using different ebay links, one specifically..
  • Vintage Lot of 6 1965 Mattel Mattel-O-Phone Records Toy Collectibles Vintage Set of 6 Mattel-O-Phone Records by Mattel. 5 records are dated 1965 & 1 is dated 1967. Records include...Barbie, Talky Toys, Familiar Friend
    mybookbarn.ecrater.com/p/6503772/vintage-lot-of-6-1965-mattel-o-phone-records · Cached page
  • Vintage BARBIE Mattel O Phone RECORD GC telephone ' eBay
    • Seller 100.0% positive ·
    • Free shipping ·
    • Shelbyville, Tennessee
    Dolls & Bears > Dolls > Barbie Vintage (Pre-1973) > Vintage (Pre-1967) ... Vintage BARBIE Mattel O Phone RECORD GC telephone
    cgi.ebay.com/Vintage-BARBIE-Mattel-O-Phone-RECORD-GC-telephone-/150549739745?pt=LH... · Cached page
  • Sep 18, 2011 | Mattel O Phone Record Discs Talking Toy...
    HI I BOUGHT A 1969 TALKING SERVICE STATION BUT THE PULL STRING IS JAMMED PULLED OUT HOW DO I FIX THIS AND GET IT TO TSLK AGAIN
    mcdevito75 here, you may not be able to as the spring on the pull string may have lost it"s tension or the pull string mechanism is just stuck. You may not even be able to get at the mechanism if it"s a sealed unit, if you can get at the mechanism a little penetrating oil may help. Contact the toy manufacturer online or phone for more help.
    Jun 26, 2010 | Toys
    1/2 strand of christmas lights do not come on
    There's a blown bulb.. take a spare globe & pull out one of the lights that is'nt working on the strand and put the spare one in if the string doesent light up try the next one and so on..
    Dec 31, 2009 | Christmas Lights Etc Santa's Toy Truck
    Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
    I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
    Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
    String on "The Farmer Says" went inside the toy.
    Oh NO! Loved that toy when I was a kid. With a bright light source, check the sides and the back of the toy for the screws. They are there somewhere. Sometimes they have little caps over them that you'll need to remove first.
    You may be able to hold the toy upside down and extract the string back out of the hole with a pair of tweezers. I know it's a long shot.
    Dec 08, 2009 | Mattel Toys
    Creative Toys YACKER TRACKER Logo
    41 people viewed this question
    Top Creative Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Creative Toy Expert? Answer questions, earn points and help others
