Question about Whirlpool SF265LXTB Gas Range
Whirlpool stove model sf265lxtb0 - top burners work but both oven and broiler fail to ignite.
5 Suggested Answers
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
SOURCE: Whirlpool Super Capacity 465
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tries turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
SOURCE: whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Posted on Jan 08, 2009
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
Broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221257
Dec 26, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool super capacity 465 oven quit lighting
Check the burner ports near the ignitor for blockage. I had one of these units, and the ignitor was not mounted correctly, and caused a similar problem
May 02, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Whirlpool super capacity 465 gas range model# sf377pegq5
Aug 20, 2008 | Whirlpool GS460 Gas Kitchen Range
Gas oven won't light
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=53999&thid=358497
Gas oven won't light (by 2 users)
Posted by MBeird on Jan 18, 2008
Can hear the clicking of the auto starter when starting the oven, but it stops after 5 seconds and then the oven simply fills with gas. Broiler still works fine as do the stove top burners. Any thoughts?
Good question? You may have a plugged up burner and or the pipes or jets may not be adjusted correctly and it could be your igniter on the gas range because it is not igniting the spark to create the flame. You may want to have it check out with an authorized service repair tech to make sure it is safe and will function well. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Jan 18, 2008 | Whirlpool SF367 Gas Kitchen Range
Whirlpool SF265LXTB Gas Range Logo
16 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
