Question about Maytag MAH6700AWW Neptune Front-Load Washer
Reset washer neptune front loader#mah5500bwq, when we cleared the cold water line,(due to soft water system problem there was a blockage) the machine initially started, but stopped midway, we have unplugged and waited 30mns, but machine will not start, the display window show 64 mns and heavy cycle is lit, but cannot change commands, please help with reset
  • 1073 Answers
SOURCE: Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Posted on Apr 13, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
TheRepairGur
  • 27 Answers
SOURCE: 1999 maytag neptune washer stops after filling up with water
There are a couple of common causes for a problem like this. First is a bad door lock assembly that also damages the machine control board (in the control panel). If this is the case the R11 resistor on the machine control board will be burnt.
Maytag has identified seven resistors that relate to specific components that need to be checked or replaced if the resistor is damaged. Listed here are the resistor identification, the circuit involved, and the recommendation:
R9 / pressure switch / check for loose connections or high resistance on switch contacts; replace pressure switch if necessary.
R11 / door lock wax motor / replace door lock mechanism and machine control board.
R51 / hot water valve solenoid / replace water valve and machine control board.
R52 / timer motor / check for loose relay terminal connections and replace machine control board.
R53 / cold water valve solenoid / replace water valve and machine control board.
R143 / (-) 24 Volt DC / contact was made between neutral and the 24 Volt DC circuit.
R162 / electrical buffer circuit / wire harness and machine control board.
Another common issue is a slow water fill fault. If the washer does not fill within a certain time the control will stop on a fault. Usually when this happens the START button can be pushed to continue the cycle.
Washing machines that won't fill or fill slowly often have a restriction in the incoming water supply -- usually in the screens of the inlet hose washers or the water inlet valve itself. Remove the hoses to inspect this condition. If the water inlet valve screens are plugged, replace the water inlet valve.
Go here for: Maytag Neptune Washer Parts
RepairClinic.com
Appliance parts, help & more
Posted on Apr 29, 2009
pride applia
  • 232 Answers
SOURCE: Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Posted on Aug 02, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
Posted on May 23, 2010
Maytag neptune MAH5500BWQ hot water fill runs slow
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Apr 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Our washing machine sat outside during a hard freeze (4 days without ever getting above 27). We had the water lines disconnected/dripping to avoid busted pipes, but we didn't realize there was a spot for...
your water valves, you have 2. may have a crack due to the freezing. they retain water inside. you have to take appart or lift the top of the washer to inspect the water valves. the main valve is the one you connect the fill hoses. the other is the one on the dispenser.
Feb 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
Water won't pump into machine
turn your water off andcheck the screen in the water lines ...both ends...both hoses...Godd luck!
Dec 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Only hot water will fill, cold water will not
If it is equipped with ATC automatic temp control turn it off and see if if you can get cold if so its the ATC sensor
Sep 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Wash time too long
if the water supply is restricted, yes this would happen. remove supply hoses, check screens, check taps
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Smelly water does not completely empty
Hello.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
  • Thank you for usning fixya.
    Jul 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Clogged screen on water intake.
    it should just come out with a nice firm, but gentle pull. problem is u need to be careful because if its that clogged up, its probably weak and might break. U can always just buy new ones at sears, or home depot.
    Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
    No flow
    Hello hedrickcari
    Welcome,
    You said, you are getting a no flow error code. This washer was installed today.If I have an air pocket, how do you get it out so the washer senses the water flow?
    First I would unplug the washer for 5 minutes and see if it resets and clears the errors!
    Make sure the door is tightly closed. (Unlike top-loaders, front-loading washing machines must be closed in order for water to begin filling. Makes a lot of sense when you think about it.)
    Then make sure the machine is plugged in to a live (or working) electrical outlet. It's a good idea to check the appropriate circuit breaker and reset it if needed or check the fuse if you have a fuse box.
    Next, turn the control dial to the proper cycle and push the START/STOP button firmly. Then turn both faucets (hot and cold) on all the way. Take a look at the inlet hoses (which go from your pipes to your washer) and straighten them out if necessary.
    Turn off the faucets and then disconnect the hoses. Clean the hose filter screens to remove any blockage that could be plugging up the water line.
    Then replace the filter screens, reconnect the hoses, turn the faucets back on, open and close the door, and push the START/STOP button firmly one more time.
    You should be rewarded with the sound of water beginning to fill up your Maytag® Neptune® washer. If you aren't, please contact Customer Service at 1-800-688-9900.
    Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag MAH6700AWW Neptune Front-Load Washer Logo
    60 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
