Kyocera 1116 prints entirely black pages, high voltage is ok. after a few pages, it goes back to normal. it happens when he starts.
    New Friend:
  • 63 Answers
Fully black could be 3 things - no charge, laser always on or dev bias out. id go with the charge contact isnt correct
Posted on Oct 22, 2013
Testimonial: "already fixed. problem was with the grounding on the opc drum. thanks."
Zanussi 1116
I would call an appliance tech. This definately is an advanced issue required by a tech to diagnose.
May 06, 2012 | Washing Machines
Entire page is black when trying to make a copy. Was working fine, now nothing... just black. What's the problem?
does the exposure lamp lights when u make a copy. if yes thenthe charging wire might be broken .check and replace it. it can also be the high voltage supply board .
Sep 12, 2011 | Kyocera CS-2550 Black and White Copier
I need drivers to install Kyocera FS-1116 MPF multi scan as I have lost the CD
Kyocera FS-1116 MPF Drivers
Visit the above link and download the required drivers for the Operating system you have on your PC
Installation Manual may also be referred.
Hope it helps! Good Luck!
CreativeTECH
Apr 15, 2011 | Computers & Internet
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB
- Defective the engine/high voltage PWB.
Dec 15, 2010 | Kyocera FS-1016 Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Can't print entire pdf documents only first page.
There may be a few possible things for your to try. Below is the list of things you can try.
1) Reinstall the PDF software that you use to open your pdf documents. (reader or acrobat) *restart machine after reinstall.
2) Remove the printer from your list of printers and faxes then add it back again
3) Restart the spooler service
click start -> run
type services.msc then ok
on new window, look for print spooler, right click and select restart service.
May 29, 2009 | Kyocera Mita FS-C5016N Printer
Completely black copies
check the "main charger wire"
Jan 19, 2009 | Kyocera Copystar CS-5035 Copier
When we print manually the whole page comes out completly black.
edithvenzor:
Try replacing the toner cartridge first, then proceed with the other items.
Thank you and let me know what happens:
Binary Bob
Problem
Cause
Solution
How common*
Comments
BLACK PAGES
DC Controller PCA is defective. If the DC Controller turns on the laser beam continuously,
the entire surface of the Photosensitive drum is neutralized causing a completely black page
Replace the DC Controller PCA
10
BLACK PAGES
Defective toner cartridge
Replace the toner cartridge
9
BLACK PAGES
High voltage contact springs are dirty or defective. The high voltage contacts are mounted on
the High Voltage Power Supply PCA and protrude into the toner cartridge cavity
Inspect and clean the high voltage contacts. If damaged, replace the High Voltage Power Supply PCA.
BLACK PAGES
High voltage power supply circuit is defective (not supplying the correct negative voltage)
Replace the High Voltage Power Supply PCA
10
some printers have the high voltage power supply on the DC controller.
BLACK PAGES
Laser/Scanner Assembly is faulty (turning laser on continuously)
Replace the Laser/Scanner Assembly
5
BLACK PAGES
Light is leaking into the printer
Make sure that all covers are in place
possible, but not likely
Nov 30, 2008 | Office Equipment & Supplies
Printing problems
Hi, There are 3 things that can cause blank pages. The most common is the laser shutter pops off on the spring side and blocks the laser from hitting the cartridge. The shutter opens when the cartridge is inserted. The cartridge guide that sits above and behind the cartridge misteriously gets eaten by the printer. Without it, the cartridge rides too high for the toner to transfer. The high voltage power supply goes totally dead. If the first 2 are ok, then replace the high voltage power supply. (There are 2 power supplies in the printer. One the low voltage power supply supplies voltage to all the boards, fans, etc. The high voltage ps only supplies voltage to the toner cartridge.)PS-The laser/scanner shutter is found under the top cover and below and by the front of the laser/scanner assembly (black box). Control of the shutter is on the left side of the laser/scanner. Good luck
Sep 03, 2007 | HP LaserJet 4 plus Printer
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
23 people viewed this question
k24674
jasbo
jasbo
