Question about Kirby G4 Bagged Upright Vacuum
With help from this site I replaced the fan on my Kirby Gen4. Now the motor starts slow then stalls. Is it ruined?
    Problem Solver:
  • 5 Answers
When the fan finally cracks and even before it spins out of balance so your motor brushes have poor and intermitent contact with the armature and could have broken the motor housing possibly damaged the field. But ruined NEVER. That machine will run 100 years :)
Posted on Apr 19, 2014
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Kirby generation 3 fan
You have to take off the top cover, then the handle pivot. Look down at the back of the armature you will see that it has a flat spot, you use a small vise grips or pliers to hold it, turn the belt pulley to the right if I remember right and turn the pulley off. If it won't come free, use a couple of flat blade screwdrivers and pry up to pop the fan off. Then put it all back together.
Posted on Feb 11, 2008
reddevil6
  • 1673 Answers
SOURCE: Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
Posted on Jun 21, 2008
After my son vacuumed up maybe a lego theDiamond G Kirby started sparking from inside housing. We took brush and checked for any loose items and found none. Any ideas and can I diy?
Sucking up a Lego or similar item normally should not have done any damage to the motor. It may stop the brush roll which may burn the belt if the belt is tight. If the item got sucked into the fan it may have broken or cracked it which could seize the motor. Remove the brush roll assembly, spin the motor shaft while you inspect the fan. Fan replacement is best to be done by an experienced technician.
Jan 24, 2017 | Kirby Vacuums
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Wont **** properly. is just moving dirt around. i have a G6 i unclogged it changed the bag. dont know what else to do.
With a Kirby that's around 10 years old, there's a good possibilty the fan is worn or broken. You can purchase one online (http://www.elikirbyclub.com/category_93/Kirby-GSix-Fan.htm for $17.55 plus shipping and handling) or at a Kirby store.
Instructions for replacing the impeller can be found at the following site.
http://www.ehow.com/how_5534689_replace-fan-kirby-vacuum-cleaner.html
Jan 03, 2011 | Kirby G6 Bagged Upright Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
Th end of the shaft that come from the motor is worn out, and won't hold the belt well. How do I change it?
Thanks for the clarification. I have never seen this problem previously in a Kirby. I wonder if the belt keeps sliding off because it's been stretched out? After about 1-2 years, the belts on the Kirby will stretch out to a point where there can possibly slide off the motor shaft. Have you tried just replacing the belt on the unit first?
If you're sure that it's not the belt that may be stretched out, and you'd like to replace the motor shaft, you certainly may do this. The only problem with this is the motor shaft is not sold by itself as a separate part. The only way to purchase this motor shaft is to purchase the entire fan assembly, which includes a new fan, and the hardware necessary on the fan assembly.
Here's a parts diagram that shows you the motor shaft is sold only in a completely assembly:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/kirby-generation-parts-diagram.pdf
If you haven't already purchased the motor shaft, here's a direct link to the motor shaft and fan assembly on our website:
Kirby Generation Fan Assembly With Motor Shaft and Hardware
In terms of installing it, we've actually recorded a video repair on how to replace the fan assembly, which involves removing the motor shaft in order to get the fan off. Since you have to purchase the fan assembly anyways in order get the motor shaft, you may want to go ahead and replace your fan assembly at this time also. Even though your fan may not be broken, on Kirby's the fans can become coated with dirt and fine dust, which can sometimes lead to the Kirby exhausting a bad smell. If you'd rather not replace the fan, you may remove the motor shaft without disassembling the entire machine, you'll just need to secure the fan somehow so that the fan doesn't spin while you're using a nail to turn the motor shaft off.
Anyways, here's the video repair that we recorded. I hope that this helps you. If you found this helpful, please kindly rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair. This is really what keeps Fixya repair professionals continue to give free repairs online.
Here's Part 1 of the video:
Here's Part 2 on Replacing the motor shaft and fan:
If you have any follow up questions, I'd be more then happy to answer them for you, please just add another comment here on the repair page, and I'll be more then happy to answer any follow up questions that you have. Thanks again for rating the repair, I greatly appreciate this.
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
Fan replacement
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
I'm assuming you mean to replace the impeller fan...if so this site has step by step instructions...
hope this helps!!!!
Jan 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
42 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
