My digistar 860UH HDMI always says I have no signal out of nowhere so not happy
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
Mar 03, 2015 | ASUS Ve248h 24-inch Led Monitor
Configuring a Sony STRDH510 - 3 HDMI & 1 composite input
Is the composite/analog signal going into the same input as one of the hdmi's? i.e. DVD,BD, etc.? If so, the receiver can only look at one of those signals at a time. To use two different signal types going into the same function, you will have to manually select where you want the receiver to look - either hdmi, analog, optical, etc. The receiver defaults to auto-selecting which signal to look at, and will always look for a hdmi signal if one is available.
Dec 26, 2012 | Sony STRDH510
Looking for a wiring schematic for a DIGISTAR tv, model # CR-20SS01D
You might try contacting Digistar Directly, here is the info:
Address : Digistar Group
B5/5/5, 4th Floor, One Ampang Business Avenue,
Jalan Ampang Utama,
68000 Ampang,
Selangor,
Malaysia. pixel_220x15_white.gif Telephone : +603 - 42534319 (Hunting Line) pixel_220x15_white.gif Fax : +603 - 42572168 pixel_220x15_white.gif Email : digista@digistar.com.my pixel_220x15_white.gif URL : http://www.digistar.com.my
Oct 14, 2010 | Televison & Video
Picking up digital tv signals
vision plustft color dvb/atv/vga/monitor dv3-t
Jan 22, 2009 | Televison & Video
Codes for 20" Digistar model tk2055d tv remote
THE BEST SOLUTION IS THE SIMPLEST ONE.
I suffered for 1 month shopping around for an universal remote control that has a code for the Digistar tv brand. It was in vain.
So just turn to the simplest way ..the programming with code search (on the guide of the universal remote control- which has not the code for digistar brand) In the paper it tell you exactly what to do. I bought a 3 device universal remote control.
On mine it showed five easy steps to follow and the remote finds itself the code and programs it .You do not put any code ever, the remote just simply WORKS perfectly. I have solved this problem just 5 minutes ago..Oh ...I forget..On the universal remote control instruction it said that you might have to press the ON/OFF button up to 200 times , so i thought "I never tried this one, better then waist days and months will no solution. I nedded to do it only for 30 times or so beffore the TV turned OFF, and than I pressed the ok button on my remote (probably to save it- or who cares-as long as you follow the instructions). Then I could turn back on the Tv and P{LAy with the remote without putting any code as the remote it programmed for the Digiistar brand..I'm so HAPPY...Try it and spread the "new"...It is Ironic ..it was there all the time...we look in more complicated zones and do not see the solution sitting under our nose:((:)))
GOOD LUCK!
Oct 19, 2008 | Televison & Video
PANASONIC HOMETHEATER SYSTEM TO PLASMA TV
Some where on the back, bottom or sides of your plasma tv you will find input jacks for the audio and video. You must know what type of inputs you want to use.
Most have have 4 types
HDMI (audio and video signal combined)
Component (red, blue, green RCA jacks for video only)
Composite (yellow RCA jack for video only)
S-video ( larger round black jack with video only)
The Panasonic should have all of those also. I am certain it has HDMI and Component.
Connect the HDMI cable into the output HDMI jack from the Panasonic into the HDMI input jack on the TV.
Then using your remote for the TV make sure you select the HDMI input for viewing.
If you use any of the other video outputs on the Panasonic just connect it to the same type of input jack on the TV. Once again check the owners manual for more detailed instruction if you need them.
You must always be sure to have the proper input selected on the TV to be able to view it.
You can also respond back with more questions if you have any.
I am happy to help.
Dave
Jun 27, 2008 | Audio Players & Recorders
Digistar modal TK2055D(remote code)
Norcent, Liteon and Digistar are all pretty offbeat brands, so if you're looking for a universal remote that has pre-programmed codes for all of those devices you're likely to come up short.
Both your URC-9911 and the much superior 15-1994 are JP1 remotes, which means you could easily program both of them to work all of your devices using JP1.
JP1 info:
http://www.hifi-remote.com/jp1/
http://www.hifi-remote.com/forums/
The URC-9911 is also upgradeable, so you also have the option of sending it back to OFA to have them add the codes that you need. In the event that they don't have a code for any of your devices, they would ask that you let them also borrow your original remote(s) so they can capture the signals and create codes for you.
Feb 05, 2008 | Computers & Internet
DVR/TV connection
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Dec 29, 2007 | Televison & Video
Source always PCM, can't get Dolby-D
PCM is standard when using HDMI cables, you are passing an already decoded audio signal to the receiver and it outputs the sound and does nothing more. The reciever calls this PCM, your PS3, when pressing select should show that it is decoding the dolby digital HD. There is no quality difference in the two. PCM is the same because it is un compressed audio. So when using HDMI, no matter the signal that the movie or music is playing, wether it be dolby or DTS, you will see PCM when using HDMI.
Nov 24, 2007 | Onkyo TX-SR605 Receiver
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
