Grease grease Logo
g
gladys malatjie Posted on Oct 22, 2013
Grease,general purpose:grease type:high load; grade:lgep 2;maximum operating temp:-20 to 110 deg c; viscosity rating:40 deg c mm2/s;physical form: lthium:color:light brown; class:2;drop point:180 deg c;mineral iol based; with extreme pressure additives application:harsh conditions and vibrations; 18kg drum;
Angell XP
Level 1:
  • Contributor 27 Answers
  • Posted on Oct 22, 2013
Angell XP
Contributor
Level 1:
Answers
27
Questions
0
Helped
4617
Points
37
Owners Manual appears silent on two questions.
1) Question posted under Jasco GE timers.Timer is otherwise not identified as type, model or brand.Certainly this information shows on product manual.
2) Copy following link to help identify timer and download possible manual:http://waterheatertimer.org/GE-timers-and-manuals.html
3) Upward operational temperature for digital timers usually ranges 120-155 F. So this should not be issue in garage until global warming eliminates all electronic gadgets, batteries, and seriously affects electric transmission lines from power plant.
4) Downward operational temperature for digital timers vary widely by type and model number of timer.Some become unreliable at freezing. Some last 1 month in freezing. Some are rated to zero F. Some rated minus 10-40 F.
5) Smart plan is analog timer instead of digital timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#applianceThis type timer will operate on electric power, and not be affected by temperature fluctuations. However timing is not down-to-the-minute 7-day as with digital timers.Note appliance watt rating before buying timer.
6) Two-outlet plug-in timers are not 2-channel timers or 2 circuit.2-channel timer means that the timer can be programmed for two separate timing programs, with each timer program controlling separate load with separate schedule for each load.
7) Example 2-channel timer: Intermatic 1125 digital timer.Note operating temperature -40F to +155, making this especially hardened timer, with wide range timing applications excluding delay functions, But with 1 year limited warranty as is typical with most timers.
http://waterheatertimer.org/pdf/024_ET1100-sell-sheet.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3helpful
2answers
What type of oil grade should i use in my 2001 audi 2.8 a4 quattro..this car came with no owners manual,and its time to change..thanks
Engine oil capacity with oil filter replacement = 6.0 litres.
Oil grade for 2001 Audi A4 Quattro 2.8
1. SAE 5W-30 / 5W-40, VW 502.00 - all temperatures.
2. SAE 10W-30 / 10W-40, VW 502.00 - all temperatures.
3. SAE 5W-50, VW 501.01 - all temperatures.
4. SAE 10W-50 / 10W-60, VW 501.01 - all temperatures.
5. SAE 5W-30 / 5W-40, VW 501.01 - bellow +15 Celsius degrees.
6. SAE 10W-30 / 10W-40, VW 501.01 - bellow +15 Celsius degrees.
7. SAE 15W-40 / 15W-50, VW 501.01 - above -15 Celsius degrees.
8. SAE 20W-40 / 20W-50, VW 501.01 - above -15 Celsius degrees.
LONGLIFE engine oil:
1. SAE 5W-30, VW 504.00 - all temperatures.
2. SAE 0W-30, VW 503.00 - all temperatures.
Please do rate my response. Thanks!
4helpful
3answers
What Kind Of Oil Do I Put In My 91 Toyota Pickup. 10W-30 or 10W-40?
Depends on the season and temperature that it will be driven in.
Generally 10w-40 is for the summer, and the thinner 10w-30 is for the winter, if you so desire.
According to the chart, 5w-30 is preferred but 10w-30 can be used in 0 deg. F up to 100 deg. F and beyond.
Fuel and Engine Oil Recommendations GENERAL INFORMATION Oils The SAE (Society of Automotive Engineers) grade number indicates the viscosity of the engine oil; its resistance to flow at a given temperature. The lower the SAE grade number, the lighter the oil. For example, the mono-grade oils begin with SAE 5 weight, which is a thin, light oil, and continue in viscosity up to SAE 80 or 90 weight, which are heavy gear lubricants. These oils are also known as "straight weight'', meaning they are of a single viscosity, and do not vary with engine temperature. Fig. 1: Look for the API oil identification label when choosing your engine oil tccs1235.gif
Fig. 2: Before installing a new oil filter, coat the rubber gasket with clean oil tccs1901.jpg
Multi-viscosity oils offer the important advantage of being adaptable to temperature extremes. These oils have designations such as 10W-40, 20W-50, etc. The "10W-40'' means that in winter (the "W'' in the designation) the oil acts like a thin 10 weight oil, allowing the engine to spin easily when cold and offering rapid lubrication. Once the engine has warmed up, however, the oil acts like a straight 40 weight, maintaining good lubrication and protection for the engine's internal components. A 20W-50 oil would therefore be slightly heavier than and not as ideal in cold weather as the 10W-40, but would offer better protection at higher rpm and temperatures because when warm it acts like a 50 weight oil. Whichever oil viscosity you choose when changing the oil, make sure you are anticipating the temperatures your engine will be operating in until the oil is changed again. Refer to the oil viscosity chart for oil recommendations according to temperature. The API (American Petroleum Institute) designation indicates the classification of engine oil used under certain given operating conditions. Only oils designated for use "Service SG'' or greater should be used. Oils of the SG type perform a variety of functions inside the engine in addition to the basic function as a lubricant. Through a balanced system of metallic detergents and polymeric dispersants, the oil prevents the formation of high and low temperature deposits and also keeps sludge and particles of dirt in suspension. Acids, particularly sulfuric acid, as well as other by-products of combustion, are neutralized. Both the SAE grade number and the API designation bottle be found on the oil can. For recommended oil viscosities, refer to the chart. Fig. 3: Viscosity chart 86821236.gif
SYNTHETIC OIL There are many excellent synthetic oils currently available that can provide better gas mileage, longer service life, and in some cases better engine protection. These benefits do not come without a few hitches, however; the main one being the price of synthetic oils, which is three or four times the price per quart of conventional oil. Synthetic oil is not for every truck and every type of driving, so you should consider your engine's condition and your type of driving. Also, check your truck's warranty conditions regarding the use of synthetic oils. Both brand new engines and older, high mileage engines are often the wrong candidates for synthetic oil. A synthetic oil can be so slippery that they can prevent the proper break-in of new engines; most manufacturers recommend that you wait until the engine is properly broken in 3000 miles (4830 km) before using synthetic oil. Older engines with wear have a different problem with synthetics: they leak more oil as they age. Slippery synthetic oils get past worn parts easily. If your truck is leaking oil past old seals you'll most probably have a much greater leak problem with synthetics. Consider your type of driving. If most of your accumulated mileage is high speed, highway type driving, the more expensive synthetic oils may be a benefit. Extended highway driving gives the engine a chance to warm up, accumulating less acids in the oil and putting less stress on the engine over the long run. Trucks with synthetic oils may show increased fuel economy in highway driving, due to less internal friction. If synthetic oil is used, it should still be replaced at regular intervals as stated in the maintenance schedule. While the oil itself will last much longer than regular oil, pollutants such as soot, water and unburned fuel still accumulate within the oil. These are the damaging elements within a motor and must be drained regularly to prevent damage. Trucks used under harder circumstances, such as stop-and-go, city type driving, short trips, or extended idling, should be serviced more frequently. For the engines in these trucks, the much greater cost of synthetic or fuel-efficient oils may not be worth the investment. Internal wear increases much quicker on these trucks, causing greater oil consumption and leakage.
2helpful
2answers
2005 Yamaha YZ 250f. suggestions on type of motor oil.
The manual gives different grade for different temp . sorry if your in america these temps are in centigrade.
if it gets below 0 deg C use the thinner oil 10W30
5deg-40deg 15 or 20W40
If it gets to 50degC 20W50
just make sure it is motorcycle oil without friction modifiers or the clutch will slip
2answers
Hammer action power there but weak
It is hard to understand what you are asking, however I have found that with the SDS drills one does NOT want to crowd them but just let the tool work with light pressure...
1helpful
2answers
Oil Changes
use 15/40 mobile delvac or 15/40 shell rotella T
1helpful
Oil
Depends on the tempurate where you live,
see this link for some great info:
http://www.bobistheoilguy.com/visc.html
MOTOR OIL VISCOSITY RATINGS
Viscosity ratings for commonly used motor oils typically range from 0 up to 50. A "W" after the number stands for "Winter" grade oil, and represents the oil's viscosity at zero degrees F.
Low viscosity motor oils that pour easily at low temperatures typically have a "5W" or "10W" rating. There are also 15W and 20W grade motor oils.
Higher viscosity motor oils that are thicker and better suited for high temperature operation typically have an SAE 30, 40 or even 50 grade rating.
These numbers, by the way, are for "single" or "straight" weight oils. Such oils are no longer used in late model automotive engines but may be required for use in some vintage and antique engines. Straight SAE 30 oil is often specified for small air-cooled engines in lawnmowers, garden tractors, portable generators and gas-powered chain saws.
Basically for your car I would run 5W-30, this keeps you covered in warm and cold climates, 10w-30 is the best choice if you live in a climate with temperatures that never go below 0degre''s Farenheight.
Hope this helps
Top Campagnolo Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Campagnolo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
