Question about GE 8uf 660vac Motor Run Capacitor 8mfd 660v 26f1034
Please answer me back add vsk_mc@hotmail.com I need 4p tel.+6627079058 thank you Beer
Room fan operates continually
the capacitor is correct for the motor
all it does is supply an over voltage burst to start the motor turning, then to keep it running while the switch is on
if the capacitor was faulty in the original motor then the motor will burn out as that over voltage is not there but the current to run the motor is so the motor over heats and burns
as to the constant running it is important to check how you attached the wires to the new motor as you may have a power wire direct to the motor instead of through the switch control
May 14, 2016 | Televison & Video
I have a juki 8700-7 and error 007 can you help me
HI THERE
PLEASE SEE NEXT;
Overload of motor • When the machine head is locked. • Check whether the thread has been
entangled in the motor pulley.
• When sewing extra-heavy material beyond • Check the motor output connector (4P)
the guarantee of the machine head. for loose connection and disconnection.
• When the motor does not run.
• Motor or driver is broken. • Check whether there is any holdup when
turning the motor by hand.
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail,com
Feb 11, 2014 | Juki DDL-8700
Hi, 1) I need a new Capacitor for my Malber WD 1000 washing machine. Can I order that from you ? How much is it ? 2) The dryer is not working - is there a way for me to troubleshoot to find out what...
hi there you say you need a new capacitor i would assume your motor is not operating .you should be able to get a new capacitor from any elec strore the size is stamped on the side ie 8uf 10 uf etc hope this helps
Jun 07, 2011 | Malber WD1000 Front Load Washer/Dryer
Hi, i have a 11 SEER (RUUD) Model# UALB-036JAZ and there is a problem with the fan outside on the condenser. It starts to turn and then makes a dead stop like its binding up, but when i take the cover off...
The start/run capacitor for the fan motor must be checked.
Turn off the power to the outside unit and open the control panel.
Follow the brown wire from the fan back to the capacitor.
Look at the capacitor. If it is bukged out on top it is definitely bad.
Capacitors can be bad and not bulged on top.
It will have to be checked with a capacitor tester or replaced with a known good capacitor of the same MFD value.
If the capacitor is good and the fan does not run,the fan motor is bad and must be replaced.
Sep 20, 2010 | Ruud Heating & Cooling
Cylinder head torque settings for a toyota 1493cc 4p petrol/gas engine (cast iron head) used in a forklift, also would like the main bearing and big end torque settings if possible please. thankyou russel
If you have a vehicle application for the motor you can get a Haynes or Chilton manual from your local auto parts store. They usual run around $30.
Sep 04, 2009 | 1989 Toyota Tercel Liftback
Connecting a motor starting capacitor
New Capacitor
herm start on the compressor
fan start on fan motor
c run or power to both compressor and fan
Apr 25, 2009 | Kenmore 75085 Air Conditioner
No driver of pc camera mc 2pc
Go to retrevo.com. If you can't find it there you can't find it anywhere.
Apr 10, 2009 | Cameras
Simpson Clothes Dryer wont start without assistance
your dryer has a start assist compressor go to this site to see it and that could very well be the problem. www.repairclinic.com/SSPartDetail.aspx?s=t-39p400-%3d%3db166i938994%PartID=938994
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
GE 8uf 660vac Motor Run Capacitor 8mfd 660v 26f1034 Logo
24 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
