Question about Crafts & Hobbies
How to reset DCC Controller software. - Crafts & Hobbies
When trying to give a decoder a new address i keeps coming up error code 12how do i get around this
this might be due to electrical "noise" on track or near by , me I use a one piece dedicated track with its own power supply to power my dcc stuff when programming them , if your not in that position financially then try using a short one piece of your own track that doesn't have ends or go anyplace , also try to avoid programming near floursent lights these things throw out tons of electric noise !! and it drives my command system nuts sometimes
Dec 03, 2015 | Bachmann Easy Command Dynamis Wireless DCC...
What is solution for E240 in canon ir 105??
E240 is a communication fault between the DCC and main controller.
Several cases were reported where the HDD was causing this. Symptoms included: Control panel locking up, machine suddenly powering off, and E240.
One case reported was resolved by replacing the main controller.
Perform HD-CHECK in service mode. If this doesn't resolve the problem replace the HDD.
Oct 30, 2015 | Canon imageRUNNER 105 Printer
I get a an error 55.1 " turn off and on??? I t was working just fine this morning. Need a little help
From the service manual:
55.1 Error: DC controller error. The device has experienced an internal hardware error.
Solution:
1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the device on.
3. Check the engine (DCC) firmware version. Update if needed. Replace the DCC (DC Controller) if a firmware upgrade does not resolve the issue.
Jun 17, 2009 | HP Color LaserJet 2600n Printer
Sony DCR-DVD106E Software
You wont need a cd copy. You can install Picture Motion Browser and all the manuals that are on CD from here:
http://support.sony-europe.com/dime/camcorders/dcc/dcc.aspx?site=odw_en_GB&m=DCR-DVD106E
Oct 27, 2008 | Computers & Internet
DCC port problem-1
You have to forced ON the DCC lead on Config - Circuit - Options - CtrlLeads.
ilker
Feb 13, 2008 | Alcatel Newbridge MainStreet 3600...
Crafts & Hobbies Logo
29 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
