Question about Microwave Ovens
Chefmate model 87000
What size is the rotating tray and where can I get a replacement?
What size glass tray do I need for my Westinghouse model WCM770B/W microwave? I broke mine and cannot find the answer in the manual.
Frequent thrift stores or yard sales, or take a tape measure to the inside of the microwave
. If your dish was square, the glass plate should likely be about 1 inch less wide and 1 inch less deep that the inside of the box.
If you have a round plastic rotator, the dish should be about 1 -2 inches bigger in diameter than the plastic rotator.
God bless your efforts.
Oct 23, 2017 | Westinghouse Microwave Ovens
Need new glass tray for Kenmore microwave bought in 1977. Model # 99371.
They made Microwaves in 1977? wow. I would try an appliance junkyard, or ebay. We have used a microwave safe plate of the right size and it worked well. Good luck!
Apr 29, 2012 | Kenmore Microwave Ovens
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
HI - our rotating plate cracked for a JVM1450BA001 micro. Do have a replacement part for this model? I believe it has been discontinued.
Even though the model has been discontinued, the tray is still available. If you go to www.appliancepartspros.com and enter the model number you should be able to find the tray there. Hope this helps you.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need manual for Chefmate Breadmaker. Model BH-215
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 06, 2011 | Microwave Ovens
I bought a house with this Microwave - no instructions etc.Should there be a glass tray for it - I know it's an older model
If there is a recess for a tray and a drive in the middle of the floor of the oven, then it should have a rotating tray. My microwave is about 30 years old and has a rotating tray.
Feb 25, 2011 | Microwave Ovens
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave dish/tray rotates intermittently.
If the turntable is not turning, you will get hot spots and uneven heating.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can get Samsung parts here.
Aug 03, 2008 | Microwave Ovens
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
Oct 20, 2007 | Kenmore 80803 Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
