Question about HP (T18M038.00) (T18M03800)
Computer says it is conected wirelessly but can not get on internet using docsis 3.0
2 Suggested Answers
  • 5 Answers
SOURCE: my computer will conect to
It can be several problems.
1. Driver of wired network adapter is not properly installed. Try reinstalling the driver. 2. Your LAN wire is defective. Try a different wire. 3. If you are using a router or switch. There might be a problem with it. Check that. 4. Your wired network settings is not properly setup. Try resetting it to default.
Posted on Mar 05, 2011
How do I disconnect my cable modem from the internet?
Turn off your wifi antenna on computer or disconnect from your wireless network.
Mar 26, 2014 | NetGear High Speed Cable Modem - Docsis...
How to conect to wifi
You need to obtain and connect a wireless router to the modem to add a wireless network. Use an RJ-45 between the WAN port on the router and to the yellow port on the TM822G (or similar Arris telephony modem). Check with your ISP. If you have set your computer to obtain an IP address and DNS server automatically, you will have the router's wired connection set up immediately.
You will need to check the router's manual to find its IP address and administrative user name and password. Using a computer with a wired ethernet connection to the router, log in and set up the wireless network; you probably will want to change the network's default name to one that is easier to remember. Enable the encryption and use a password on your wireless network. (I recommend disabling the guest account option.)
Then go to your devices that can connect to the wireless network and set them up to find that network. (For some tablets, see the Settings > Network > Wireless menus. On Windows 7 and 8 computers, enable the wireless adapter if needed. Then go to the Control Panel > Network and Internet > Network and Sharing Center. Then set up a new connection.) Some routers have a WPS button on the back or front. If you press this button when prompted by the device, the router will send out a signal that will pair the device and the router without much effort. For other devices, you will need set the device to search for available networks and then type in the password.
I hope this helps.
(I have a Linksys wireless router but there are other manufacturers with well-reviewed routers.)
Jan 13, 2014 | Arris Tm802g Touchstone Docsis 3.0...
Motorola SBG6580
Open Device Manager and set the wireless adapter Power tab to not turn off to save energy. Or modify Sleep mode to not turn off wireless adapters and USB devices. USB if you use a USB wireless adapter.
Jan 29, 2018 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I wanted to know what is the best wireless router compatible with motorolla SBV5120 cable modem? thank you very much
The Motorola SB5120 SURFboard® is a very popular, solid and reliable cable modem compatible with most cable providers. If your modem is two years or older, upgrading to the SB5120 has been known to show speed improvements up to 3X faster than older DOCSIS 1.0 modems. Set up is simple and fast.
  • Compact design: With its attractive and compact design, this cable modem won't clutter up your work space
  • Easy to maintain: Simplify troubleshooting with the handy font-panel LEDs and built-in HTML-based diagnostics
  • Stand-by switch: Disconnect the signal without unplugging the modem with the top-mounted stand-by switch
  • DOCSIS™ 2.0: Take advantage of DOCSIS 2.0 technology for up to three times greater upstream capabilities than older modems running on DOCSIS 1.1
Linksys BEFCMU10
Quick to set up at a great price, the Linksys BEFCMU10 offers fast connections to your cable broadband provider. Connect it directly to any PC with an available USB or Ethernet port, and you're ready to surf the Internet. With the Linksys Cable Modem, you'll avoid monthly rent charges, and make the most of your high-speed cable Internet connection.
  • Compliant with all industry standards: DOCSIS™ 1.0, 1.1, and 2.0 - compatible with any cable Internet provider
  • Ports: Ethernet, USB & Cable
  • Buttons: Reset
  • LED Indicators: Power, Internet Cable, Internet Activity, Ethernet & USB
  • Easy installation: One phone call to your Internet service provider completes the setup
D-Link DCM-202
D-Link's DCM-202 Cable Modem is powered by TurboDOX™ bandwidth acceleration software increasing your download speeds up to 20 times. The DCM-202 makes your broadband connection more efficient and effective by clearing network congestion, resulting in a boost in download speeds. With the DCM-202, you will get more out of your broadband connection with increased bandwidth and enhanced performance.
  • Always On, Always Connected
  • DOCSIS™ 2.0 Certified
  • Ethernet or USB Connectivity
Netgear WGT624 Super G 108 Mbps Wireless Router Netgear's WGT624 108 Mbps Wireless Firewall Router is 10 times faster than 802.11b routers providing 4x the range of 802.11b devices, and double the range of most other 802.11g products. Your home network is secure with over 10 security and privacy features including a double firewall and wireless encryption. Netgear's Smart Wizard set up software gets you connected in 5 clicks or less!
  • Interoperable with existing 802.11b and 802.11g networks
  • Smart Wizard gets you up and running in fewer than five clicks
  • Lighted power, test, Internet, wireless and LAN status icons
  • Works with most Internet gaming applications that support Universal Plug and Play
Dec 12, 2010 | Computers & Internet
I have a router Zywall 2 conect to de provider. Also i have a 7 pc-uri and a zyxel p-320w conected at IP-time what is conected to the Zywall. In the zyxel p-320w i have 5 notebook conected by wireless and...
use the same subnet mask
255.255.255.0 - is common class of ip
192.168.0.1 - router
192.168.0.2 - 192.168.0.19 assign for printers and routers
192.168.0.20 - 192.168.0.254 assign to computers
Feb 12, 2018 | Zyxel Prestige 320W Wireless Firewall...
Hello. I have wireless Router 802.11g / 2.4GHz. I have 3 PC i my house , but can only be on the internett with one of my computers. How can I set up my Router, so I can be on the Internett with all 3...
Sorry my anwser can be in spanish or english only.-
1.- All the conectivity devices, have a fisical address, and this is called "Mac Address", and is unique in the World.
2.- So,your wireless router have ones, and each computers too.
3.- The ISP (Internet Source Provider), only permit the Mac Address of the First computer only, and It know only this, so the Router Mac Address is unknow for they, and the rest of computers too.
4.- But, you can configure the firmware of the Router, so it show to the ISP the First Computer Mac Address allways, and this you can do in Items "Lan Configure" writing "Clone Mac Addres".-
5.- So, the ISP don`t see the Router MAc Address, always will see the Firts computer Mac Address, and the Router share the Internet Conectivity with other computers without problem.-
6.-For to configure the Router, in the browser you must write the followen Ip : 192.168.0.1 or samthing lake that, for this you must have conected your computer to the Router with an Ethernet cable with RJ-45 connectors.-
That is all.-
sincerely.-
Aug 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
My wireless adaptor does not work properly
These wireless dongles can take time to conect after pc starts some times they take up to 3 minutes to configure. What you could try doing is changing the brodcast type on the main modem and reconfiguring the dongle on the other pc to conect might work out faster for conection and better.
Nov 30, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
Need to get wireless on my laptop,
No, the SB5100 is just a cable modem, not a wireless router. You will need to keep your sb5100 but you will need to purchase a wireless router if you want wireless on your laptop. If you can also plug your laptop into the sb5100 via an ethernet cable for your internet connection. Linksys and Belkin and others make wireless routers that you can use for your wireless connections.
May 01, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Wireless ir conected, but don't works
My name is ArmyMason, I have a suggestion for you. In Internet Explorer click on file and see if Work offline is checked. If it is unchecked it and try again. If this solution doesnt work might I suggest using our premium service or live chat.
Thanks,
ArmyMason
Feb 24, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Reloaded Windows Vista
you can try the ff:
► double check the wireless if it's enable or disable. click start > start search > windows mobility center > turn the wireless network ON.
1) reinstall the wireless driver of the computer using the driver disc or using the recovery partition....
2) tried to set-up the home wireless conenction in "Home Set-up Wireless Network" and follow the instruction.
3) reseat wireless card if it's reseatable.
4) download the BIOS update using ethernet cable from the pc website support.
3) contact Internet Service Provider.
4) reinstall the windows to the factory condition.
Sep 19, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
