Question about Dyson Vacuums
Dyson dc17 thermal switch - Dyson Vacuums
SOURCE: How to replace belt on Dyson DC17
Preface: Dyson folks were great, answer so simple I was embarassed after I called. 5 minute fix.
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Posted on Apr 04, 2009
SOURCE: roller motor on a DC17 dyson wont turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
Posted on Aug 09, 2009
  • 4 Answers
SOURCE: Power shuts off on my dyson dc17 animal
I had the same issue. Got on the phone with Dyson. THe vacuum has a safety feature where if the motor gets too hot it cuts off. You have to leave it for 45 minutes or so and then it will work again. There is an underlying issue though. My problem was the black gasket thats in the debris bin shifted, probably from when emptying i pushed it on something. The black gasket should actually hang off the bottom like a skirt and the 2 groves should fit in on the groves of the gray mechanism. This seal is what provides 100% suction. Because of this..my vaccumm has been accumulating pet hair by the belt which i hear alot of people talking about and especially in the filter area. This is because I broke the seal by not having the gasket in place properly and it wasnt sucking 100%. They are sending me a complete new cyclone unit which has the debris catcher as well as she said its probably so caked up with debris it will never work again 100%. no questions asked they are sending it to me free of charge.
So if you remove the clear cyclinder debris catch thing all you will have is the purple cyclone on top and on the bottom is the black rubber gasket....
Posted on Jan 04, 2010
Vac Belts
  • 701 Answers
SOURCE: changing the belt on a dyson dc17
Here is a link to the belt you need and the manual which has instructions on how to change the belt:
Dyson DC17 Belt and Manual
Posted on Feb 07, 2010
  • 53 Answers
SOURCE: dyson dc17 animal stopped sucking. brush still
Make sure the flexible hose that connects the beater brush housing up to the connection up by the dust bin is still connected. It could also have a hole in it so check for that as well.
Posted on May 31, 2010
How do i replace dc17 thermal switch. i have
I don't believe there is an external thermal reset. It is most likely built into the motor.
Oct 22, 2013 | Dyson Vacuums
My carpet nap is very thick and it is very hard to vacuum with my Dyson dc17 animal. I need to know if there is a way to adjust the height on the vacuum
Hi Deb,
I'm sorry to hear you're having difficulty using DC17 on this particular carpet type. DC17 is engineered to adjust automatically to different floor types, and does not need manual height adjustment.
Carpet manufacturers sometimes recommend vacuuming deep or delicate carpet piles with the rotating brush bar turned off. We'd recommend checking with the manufacturer of your carpeting as they'll be best placed to offer advice on the correct way of cleaning it. To turn off the brush bar on DC17, just use the silver brush control switch next to the red on/off switch.
It's also worth checking that the soleplate is fitted correctly. Any dirt or residue on the soleplate can be removed with a damp cloth - make sure it's completely dry before refitting it. You can find out how to remove and replace it here: http://content.dyson.com/support/help.asp?article=962&product=DC17-ANIMAL
I hope this helps, but if you would like further advice after you've given this a try, please email your details to askdysonUS@dyson.com. One of our experts will be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 23, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Why does my DC17 Animal vacuum keep shutting off?
Hi Emmeline,
I'm sorry to hear you're having difficulties with your DC17. From what you've described, it sounds as if the thermal cutout feature is shutting the machine down to prevent overheating. If you've already tried washing the filter and are still experiencing the issue, I'd encourage you stop using the cleaner and to contact us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Nov 16, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I opened my dc17 dyson to clean teh motor. trying
I'm not sure about all the switches used in the vacuum, but I recently took some pictures of the power button assembly. The buttons in the picture below are (from left-to-right): Circuit Breaker, Brush Switch, Power Switch
The next picture shows how the plastic buttons that operate the brush and power switches should go together:
And finally, this is how the power button assembly reattaches:
Jul 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Where can I purchase a Dyson DC17 power switch?
Hi its Darran at Dyson.
Please call our Helpline on 1866MYDYSON so that we can help you.
Kind regards
Darran
Dyson Customer Service
Apr 15, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson blueprint beater bar won't turn
The Dyson DC 17 has a rug / floor switch on the head of the vacuum. Please check to make sure the switch is in the Rug position. If the brush roller still does not turn then you have broken the belt and need the following part.
Dyson DC17 Geared Drive Belt, Genuine Dyson Part # 911710-01 - Free Shipping
Apr 08, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
In need of a picture of the on/off switch for Dyson DC17.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Feb 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
101 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
