Question about Samsonite Tripod
Tsa002 stuck open - Samsonite Tripod
How can I open my TSA002 lock witch I fogot the cod.
Presumably it is a three digit code, so all you have to do is start at 000 and progress steadily towards 999. if you make twenty attempts per minute, it should take less than an hour. Unless, of course, the witch can do it by magic.
Jul 15, 2014 | Samsonite Tripod
Tsa002 change combination
Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
Jul 04, 2014 | Locks & Locksmithing
TSA002 - E110 Key
Ask the manufacturer.
May 09, 2014 | Luggage & Travel
How unlock Samsonite TSA002
You can go store and unlock it.
Aug 01, 2012 | Samsonite Silhouette 11 HWatch
I forgot my combination for my samsonite spinner tsa002
Hi Daniel
Wanna give this a try?
On you tube there are some exaples on how to open it where it is difficult to explain verbally
http://www.youtube.com/watch?v=OfchUwkEckI&feature=related
good luck
rene
pls add kuddo's i try to get wizzy
Jun 08, 2011 | Samsonite Tripod
TSA002: How to change the code? I still have the original code which is fairly simple. We want to change this now but unfortunately don't keep the booklet. TSA002: Is it possible to get a key - just...
Try asking your questions again in the proper category since the expertise in this area is tripods and cameras, not luggage. If you ended up in tripods after starting in luggage, contact the FixYa staff to correct the problem. The other categories experts will be much better at answering your specific problem than the photo guys.
Sep 23, 2010 | Samsonite Tripod
I have a TSA002 lock which came with the luggage bag and having set the code accidentally, I've not been able to decode it. How can the problem be solved? I know there's a keyhole and a TSA 002 key will...
This link actually shows a man picking a TSA002 lock with a pair of standard tweazers. You can give that a try??
Sep 05, 2010 | Samsonite Tripod
Get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
Forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Sep 17, 2008 | Samsonite Tripod
Photography Logo
Top Samsonite Photography Experts
ittco
Level 1 Expert
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
